Flat Springs
Old Sep 3, 2012 | 07:17 AM
7mg4me's Avatar
Flat Springs
So I looked and couldn't find a whole lot on this, and what I did find seemed to not really address the problem. I have a 7m in the bay and a SAS. I am using stock toyota RUF but that only caused my springs to be level. I then added another stock leaf into the pack to see if that would fix it, but it didn't seem to fix the problem. Is this going to be a problem? I have a set of lift springs i got from the scrap yard off of a larger chevy burban, I am just not sure if adding them would fix the problem or not. I think it should, because one leaf has about the same load as does the entire pack currently on there. ( I tested this crudely by flipping them upside down and standing on them and measuring how much they traveled down. I weigh in the 200lb ball park.) The pack moved about 3" but one leaf only moved 1.5" ish. Any help is appreciated.
here's a pic of the springs.
Old Sep 3, 2012 | 07:35 AM
DirtyOregonKid's Avatar
That picture didn't work
Old Sep 3, 2012 | 08:32 AM
7mg4me's Avatar
Sorry I tried again but it didn't work. So there are 3 plus overload. The three springs are flat against the overload. Shouldn't there be some kind of arch to them? For example if i put a jack under the axle and lift it up there is no up travel on the springs. It just lifts the truck right off the ground.
Old Sep 3, 2012 | 09:07 AM
Go to http://imgur.com/ and upload your pictures there. Then you just cut an paste the link they give you into the box here. I don't think anyone is going to be able to help you without pictures.
try to get a shot of your shackles if you can as well.
Old Sep 3, 2012 | 09:33 AM
7mg4me's Avatar
<img src="https://i.imgur.com/YC1SG.jpg" alt="" title="Hosted by imgur.com" />
Old Sep 3, 2012 | 09:38 AM
7mg4me's Avatar
http://imgur.com/HfZea
Sorry heres the correct one
Old Sep 3, 2012 | 09:44 AM
can we get a shot of the shackles now? They aren't sitting on the frame are they?
Old Sep 3, 2012 | 11:58 AM
7mg4me's Avatar
The springs are sitting against the body mount at a 30° angle
Old Sep 3, 2012 | 11:59 AM
7mg4me's Avatar
Sorry the shackles
Old Sep 3, 2012 | 01:58 PM
TrikeKid's Avatar
Add more Toyota leafs, most RUF packs are 6-7 leafs and ditch the overload, takes at least 2 pair to make one set of RUF springs.
Old Sep 3, 2012 | 02:40 PM
mudpunisher's Avatar
not running shocks will def wear the springs out pretty quick too.
Old Sep 3, 2012 | 02:43 PM
runs-on-4's Avatar
put a add a leaf in it if you want more arc, id say they look fine i run ruf and theyre pretty flat . do you want more lift/ uptravel? or do you just not want flat springs
Old Sep 4, 2012 | 08:43 AM
7mg4me's Avatar
Well i was just wondering if it was bad to have the springs flat. I ended up putting the 2 add-a-leafs from a chevy i found at the scrap yard in. They gave it more of an arch, and i bet when i get the shocks in place theyll be all good. So (ill include pics later) but with the slight arch v no arch what effect would that have on my crawling?
7mg4me's Avatar
Thanks by the way for the help
Old Sep 4, 2012 | 02:37 PM
runs-on-4's Avatar
i like flat springs my truck has about 2 inches of up travel, i like to keep mine as low as possible, its all about what you like as far as crawling it will just giv you more up travel but a higher center or gravity
Old Sep 4, 2012 | 05:48 PM
7mg4me's Avatar
Ok that makes sense. Thanks everyone for the help.
punks_is_4x4
May 31, 2016 06:03 AM
RickyD
Oct 2, 2015 07:53 AM
JookUpVandetti
Sep 17, 2015 09:25 PM
Jake28296
Sep 16, 2015 06:10 AM
