lets talk 22r timing
Old Aug 23, 2012 | 03:38 PM
my 75 toyota's Avatar
On my 87 pickup with a 22r engine. I just rebuilt it with the ENGBLDR kit and RV cam. So i have read that a 87 model year with a manual timed at 0 , 5 or 8 degrees. Which is correct. Using a Vacume guage and getting the vac to 18 it runs alot better now and starts with a bump of the key but after checking with a snap-on light its running at 13 degrees. Is that normal. If i set to the lower numbers it has a bad hesitation and idle. This engine is also running a Weber 38performance carb set to 3 psi of fuel and vac advance is on the port closest to the radiator.
Old Aug 23, 2012 | 03:39 PM
Opps the port closest to valve cover has a blown diaphram if thats the port i need does anyone know where i can find a good used vacume advance or a complete oerformance dissy
Old Aug 23, 2012 | 06:18 PM
snobdds's Avatar
For a 22r you time it by removing the vaccum advace and timing it to 0*. Then once the vaccum line for the vaccum advced is hooked up, it will be around the 8* range.
Old Aug 24, 2012 | 06:13 AM
Yes you can set base to 0 then hook up the one port on dissy to take it to 8 then the second port to carb. Heres the thing my carb only has one vac port to hook to so i have to leave other capped off no place to put it
Old Aug 24, 2012 | 06:25 PM
abecedarian's Avatar
should have one port from the carb and one from the manifold, no?
Old Sep 13, 2012 | 09:44 AM
4x4jeffyota's Avatar
sorry to thread jack but I have a question. Im currently battleing a timing issue. When I plug the vacuum lines from the distributor I set timing to ''0'' and then reconnect the lines but timing doesnt move. Whats up with that? Should I replace distributor and vacuum advance?
icentropy
Sep 16, 2020 02:47 PM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
colinmil
Jul 6, 2015 04:03 PM
