Loping cold idle below 50f
Old Sep 11, 2012 | 03:25 PM
sechott's Avatar
Question Loping cold idle below 50f
I searched the Internet for this problem I have with my 88 3vze 5 speed with no luck. The engine starts right up now that I worked some things out, it use to take a lot of cranking on a cold morning. Now it will idle about 1200 RPMs until it starts getting halfway to operating temperature. Then it will start loping for few minutes 6-1500 RPM a second only without applying throttle. As soon as I put pressure on the throttle it will behave normal. When it gets to 180F it idles normal. No issues on a warm morning, No power loss, engine does not die, and I don't notice it decelerating in gear.
Hoping someone will have an idea.
Old Sep 12, 2012 | 01:40 PM
sechott's Avatar
No one has an idea. I was talking to a few guys at work one guy says it could be the knock sensor. I don't think he is right, plus it doesn't give any codes.
Old Sep 12, 2012 | 03:13 PM
rworegon's Avatar
What have you looked at already? Cleaned the MAF? Checked spark plugs? Vacuum leak?
Have you looked at the FSM poor idle diagnostic section?
Old Sep 20, 2012 | 04:06 AM
sechott's Avatar
I looked thru the FMS nothing describes the symptoms. A few other things I noticed, the smallest load to the engine like dragging the clutch it will behave normal. even slightly turning the steering will stop the loping. Very strange. I also took the intake off cleaned it all out, no difference.
jetpilot
Aug 15, 2015 06:48 AM
JefferDean
Jul 31, 2015 10:39 AM
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
ty1er
Jul 19, 2015 06:42 PM
