PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 [101] 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. vibration question
  2. trucks running and driving; now a new problem
  3. 95 4 runner looses power
  4. torsion bar help
  5. 3VZE ECT Sensor - Where is it?
  6. Alt. light flickers
  7. 88 4runner running rough
  8. Does this describe a bad voltage regulator?
  9. Schreaching! when i push clutch in
  10. Question regarding front axel nut socket purchase
  11. Valve seal replacement
  12. Learning to drive: Wreckage
  13. '91 toyota 4runner : Coolant leak from underneath body
  14. 88 4Runner FIXED rear glass replacement
  15. ADD Elimination - Bits of Gear Fell out of the drain plug.......
  16. 1st Gen 4Runner Rear Slider Windows Leaking
  17. What happens when I short "T" & "E1"?
  18. 92 5 speed manual tranny rebuild?
  19. Driveline Vibration, Third Member?
  20. Power windows in 1995 4runner acting wierd
  21. shocks & struts
  22. odd issue on freeway, just died for a second...
  23. 89 22re not starting
  24. No full throttle power
  25. 1991 3vze no start
  26. Save me from a McGyver ground wire
  27. Philbert's 87 4runner W56 tranny swap/build thread
  28. Dropped Socket & Extension Down Drainback Hole !
  29. 4Runner license plate lights not working? Try this.
  30. 90 4runner 3.0 is possesed
  31. VSV making vacuum leak noise when active (AC on), is this normal?
  32. Replacing 22re high pressure fuel lines at injectors
  33. anyone with a vacum diagram for 1989+ 22RE?
  34. 1st Gen 4Runner IFS - Steering Stop Knocking Noise?
  35. 1990 4runner Oxygen Sensor
  36. Swapping IFS Center Sections to Avoid Setting up Ring and Pinion
  37. 4wd in the snow
  38. hubs locked front propeller shaft doesnt turn
  39. 3VZE rebuild nightmare
  40. shift levers interference
  41. what problems can a bad cat or muffler cause
  42. dear knock sensor
  43. Horn.....
  44. I need pictures of a 22r engine, preferably where the vacuum hoses and such hook up.
  45. 22re random missfire and power loss
  46. 22RE shakes at idle and smooths out with acceleration
  47. 1989 pickup 22RE very bouncy on any road imperfection
  48. ready to swap front ends....what all do i need to know/do??
  49. Ideas for stripped 24mm diff fill plug
  50. 94 4runner knock?
  51. 93 22r-e, trouble when it rains.
  52. Rear end noise
  53. 4Runner side window popped out?
  54. Mid 80's Cressida AFM Swap
  55. Toyota Cressida AFM Swap...Info please?
  56. 86 4runner knowledge
  57. Custom Tailgates?!
  58. 89 22re pickup heating problems
  59. 88 4runner cb mount ideas
  60. 22re turbo idle
  61. 22RE Exhaust Manifold Interchangeability?
  62. Lets talk about AFM,s
  63. Rear quarter pannel body rot...best way to fix?
  64. unpredictable power delivery
  65. Dash lights don't work on 88 pickup
  66. Ruff cold start?
  67. R150F tranni removal FSM questions
  68. L.C.E. Timing Chain Conversion Kit..going to double chain..
  69. New timing chain and not reving up!! Help appreciated!
  70. 1986 22re rebuilt and now dead!!!!
  71. Electrical Connector to 3.0 vze Intake
  72. Done with 3.0 vze Rebuild but Have Extra Hose
  73. I have a couple of issues with my truck after doing my timing chain
  74. Grill compatability? 1980 -1995
  75. running rough/missing when warmed up
  76. PCV Valve Stuck in 22re Valve Cover
  77. 22re Coolant hoses? - 1st gen 4runner
  78. Strange tranmission issue
  79. 95 runner dies when throttle is touched
  80. Really need some help fast - engine dies and sporadic revving
  81. Door won't open from the outside (1994 truck)
  82. Why do brakes matter when engaging auto hubs?
  83. Tyring to trace wires form O2 sensor to ecm
  84. Toasted clutch?
  85. Rough ide. Vacumn leak? Picture - what is this part?
  86. Timing belt pulley removal, it's stuck
  87. 3VZ-E tranny swap
  88. 88 v6 starts but doesnt stay running
  89. 92 4runner, 3.0 flooding out
  90. Torque spec
  91. 3rd members interchangable?
  92. Pro Comp Skid Plate
  93. gear oil in the steering box?
  94. Changing clutch, rear main seal ? with pics
  95. 1st gen 4runner+early 80's pickup
  96. whining/ grinding noise in front end
  97. ECU Self-Diagnosis (Paper Clip)
  98. Should I Resurface cylinder Head?
  99. 1990 runner stuck in 4WD
  100. my 4runner was born in Area 51
  101. Tail light/turn signal light voodoo '94 4Runner
  102. Electrical gremlins during headgasket fix
  103. Possible Fuel Filter Redo w/ Aftermarket Setup...Thoughts?
  104. This issue eludes me
  105. Doug Thorley vs. LCE Catback
  106. Need ECM diagram 89 22re 4x4 m/t
  107. turbo help
  108. 1st Gen 4Runner - Leaking Roof in Portland, Oregon
  109. Brembo vs. Napa
  110. A340H question about converting to gear driven t-case??
  111. If anyone is having "poor running" problems...
  112. Missing hose causing misfire.
  113. i need help. i need to find a cheap way to lift my front end
  114. 1st gen 4runner-access to heater fan switch
  115. 94 Speedo Help
  116. 22re won't start for some reason
  117. Changing a 91 pickup from 2wd to 4wd. I have some questions.
  118. Front End Binding When Hubs Are Locked
  119. Replace VSV to improve fuel economy?
  120. ARB RD-90 Install Question
  121. 91 pickup new interior
  122. 1988 brake booster, will a 1994 work>?
  123. Life Lesson Learned
  124. Console Question
  125. 3VZE Throttle Position Sensor
  126. 88 v6 starts but doesnt stay running
  127. 22r timing issue
  128. putney rocker arms
  129. Steering Problem
  130. 1993 3vze runner missing oil cooler
  131. '94 3vze white smoke on cold start and rough idle when cold
  132. 4runner hiccups and power loss uphill
  133. '87 4Runner mid-range flatness fix
  134. Overheating... & more
  135. 87 22r prob (I believe)
  136. 1992 No 4wd light...ADD
  137. toyota diesel engine for sale on cl in ga.
  138. How Do Our Distributors Go Bad?
  139. Oil Leaking at Timing Cover Bolts
  140. Help 13mpg!! mid road trip and have another 3,000 miles to go
  141. 90 3.0 4RUNNER stopped and will not start again
  142. Rebuild question on crank turning
  143. Transmission leaks and overheats
  144. transmission question
  145. vacuum leaks
  146. clutch problems
  147. 5 speed trans swap
  148. 91 toyota not firing on #3
  149. 1994 22RE rebuild?
  150. Truck won't start. Has air, lots of spark, fuel through filter. Suggestions?
  151. bucket seats...
  152. RPM's dropping
  153. need help related to an oil mystery of mine!
  154. 91 P/U Tranny advice wanted
  155. Need some brake help guys- on a road trip
  156. HELP!! No oil pressure and engine is idling wide open
  157. List of 22R Engine Bolts
  158. New top end n somehow found coolant in pan help
  159. Poor Acceleration/MPG
  160. Rear lift on 88 4runner
  161. 22rte issues with performance`
  162. 98 4Runner Headlight problems
  163. Truck 'bucks' when cold...
  164. '88 won't start, just a single "click"
  165. Confusing electrical issue, anyI contact ideas?
  166. Gear oil weight question
  167. Starting/Accelerating Issues, Please HELP!
  168. passed smog...but still issues with cel
  169. speed sensor
  170. Seafoam Question!
  171. 95 3vze oil pan gasket?
  172. k&n air filters
  173. Bad Idle. Changed ignition items won't crank over.
  174. Idling REALLY high when cold.
  175. 22R radiator leaking coolant
  176. Need more rear lift
  177. H4 to L4 mechanism
  178. 3vz shaking until warm.
  179. Low Oil Pressure after Oil Pan Gasket replacement...
  180. 88 v6 pickup ECU pinout(s) to air flow
  181. 3vze lifter question
  182. Valve clearance/shim adjustment - '88 3VZE
  183. Rear defroster debugging
  184. speedo gear question
  185. 22re engine stall
  186. 1 rotten Frame ... 1 rotten body ..... what to do?
  187. Rear Leaf springs with 2" of lift
  188. Replacement Glass for a Camper Shell?
  189. genuine head gasket diference
  190. 88 v6 pickup sputters and wants to choke out when trying to drive
  191. Are 3vze Heads Interchangeable??
  192. I thought a U joint was going...
  193. 22R wrist pin bearing failure...
  194. 91 fuel pump issues / question
  195. Check engine light flikering on in 92 22re
  196. Air control Lever
  197. Long High idle after start up
  198. Intermittent starting trouble
  199. Cab Fuse Box ID?? Help!!
  200. Slave Cylinder Over Extends - What's Wrong?
  201. where it find oem parts for my 86 pu
  202. Rear Tailgate Gutting Question - Rear Window Regulator Elimination?
  203. IFS jerking and pulling in 4wd?
  204. Clutch pedal broke?
  205. Steering gear, rebuild or replace?
  206. 2wd Oil Dip Stick Lenght??
  207. Swapping Interior Door Panels from 2nd gen to 1st gen?
  208. Brakes going to the floor
  209. 1989 22re will not stay running?
  210. 22rte breaking up in boost.
  211. 86 SR5 4Runner value+front oil leak
  212. 22RE Exhaust Leak need help ASAP
  213. Sun roof?
  214. After market exhaust installation question
  215. Exhaust Manifold Outlet Flange... Where to buy?
  216. OEM Plus Parts
  217. advice: engine or transmission problem
  218. No brakes after caliper rebuild??
  219. 94' 22RE Tick + High idle, advise appreciated
  220. oe toyota cb radio
  221. 3.0 removal help
  222. Roll bar and Grill guard
  223. 86 with bad shudder
  224. 3.0 Coolant Leak Above and Around Thermostat
  225. transfer case seized into transmission
  226. It's always the last place you look, random miss.
  227. 22re goes dead past 1/4 throttle
  228. 1st gen 4runner fiberglass bedsides...do they exist?
  229. Turning over but not starting
  230. Truck sputtered out and died. Won't Start. Smells like gas.
  231. New Parts!! Question of Value
  232. How did you remove oil pressure sender for SR5 gauge swap?
  233. New gizmos: lights and backup cam
  234. 3.0 Very slow and 10-12mpg
  235. Is 190F thermostat to hot for 95 3vze
  236. Back window help
  237. 1990 bench seat replacement
  238. Flexplate bolts being too long but are same bolts thta...........
  239. On and off CEL..codes 4 and 11
  240. First Fuel Filter Problem
  241. Low Tone Groaning Noise
  242. 86 4x4 22rte flooding no injector pulse
  243. 85 4runner timing on 22re... too far advanced.
  244. Gas tank compatibility
  245. Motor knocking, barely idles, wont accept gas. Toast?
  246. Trouble with ADD 4x4 4wd trouble
  247. W56 clutch fork pivot ball problem
  248. 4:88 gears in 94 pickup
  249. EGR Filter?
  250. Code 14 fun (3vze)
