22re engine stall
Old Dec 20, 2011 | 04:49 PM
bpshooter's Avatar
22re engine stall
i am new to this forum but have heard a lot of help is offered on here.i have a 89 truck with a 22re. just recently it has started to stall or stutter when accelerating. i installed new filter and seem to be getting plenty of gas.it turns over and will start after a few windings.it stalls when mashing gas pedal quickly but will keep running if you let off. thanks for any help,been scratching head alot
Old Dec 20, 2011 | 04:59 PM
93YotaGuy's Avatar
Change the fuel filter and see what that does.
Old Dec 20, 2011 | 06:13 PM
92dlxman's Avatar
timing is good? any check engine light? more specifically, any codes?
Old Dec 20, 2011 | 07:15 PM
bpshooter's Avatar
changed filter and no codes or lights
Old Dec 20, 2011 | 07:42 PM
4Crawler's Avatar
I would check the intake plumbing for hidden leaks. Not uncommon for the rubber bellows sections to develop cracks and let in un-metered air, especially when you change throttle setting and that causes the air flow to change and that flexes the rubber and opens up a crack:
- http://www.4crawler.com/4x4/CheapTri...shtml#AirLeaks
Charecter1
Nov 6, 2023 10:08 AM
Colington
Mar 8, 2020 09:51 AM
steve miller
Oct 10, 2015 01:40 AM
crashburnoveride
Aug 28, 2015 09:20 PM
Jnkml
Jul 6, 2015 01:20 PM
