Save me from a McGyver ground wire
Old 01-03-2012, 03:50 AM
Yura Nassle's Avatar
I have a 93 yota V6 4x pickup. (not SR5). Recently, my oil pressure guage on the dash stopped picking up my oil pressure sending unit.
The wire that clips to the sending unit is good. The new sending unit is good. And the gauge on the instrument panel is good.
My only theory was "bad ground". I then clipped a temporary ground wire to the engine and touched it to my sending unit. The darn thing worked. Even the old sending unit worked.
Why in the hell is the sending unit not grounding itself anymore? I cleaned the threads where the sender screws into with no results. Theres only one wire to the sending unit. So I assurme it grounds itself.
I really dont whant to McGyver something.
Does anyone have any ideas. Please!!!!
Old 01-03-2012, 04:37 AM
FattMaanLittleTruck's Avatar
Your engine is not grounding as well as it used to.
check your grounds at your battery, battery to body sheet metal and sheet metal to engine metal
Old 01-03-2012, 04:39 AM
waskillywabbit's Avatar
McGyver would have it fixed and not need to post on the Internet.
:wabbit2:
Old 01-03-2012, 04:45 AM
DIHOWARD's Avatar
Is there Teflon tape on the threads of the sending unit?
Old 01-03-2012, 04:49 AM
Bassmastry101's Avatar
:wabbit2:
With a pop sickle stick and a rubber band!
.....and maybe duct tape.
Old 01-03-2012, 04:54 AM
93toyrunner2's Avatar
Add to the check list: Firewall to back of engine, passenger side.
Old 01-03-2012, 06:35 AM
Staff
Terrys87's Avatar
Here is a list of ground locations.
Link: https://www.yotatech.com/forums/f116...-guide-194413/
Old 01-03-2012, 07:02 AM
3VZE, not 22R
http://www.ncttora.com/FSM/1990-1995...c/connecto.pdf
Old 01-03-2012, 07:21 AM
Staff
Terrys87's Avatar
Thanks 93toyrunner2.. I overlooked his posting of the 3.0, but glad you posted the link to it. I will add it to my 88 build thread for a quick reference. Thanks again.
Old 01-04-2012, 12:18 AM
Thanks everyone. I new that using "MacGyver" in my post would attract some good help.
I think that the ground between the engine and fire wall is my best bet. A few months ago, I had a coolant hose spring a leak in the same area.
Old 01-04-2012, 05:34 AM
TNRabbit's Avatar
Ditto to all the above about grounds. In addition, due to age & corrosion, you should probably remove, clean & re-install ALL major grounds. You should have seen the plug-in connectors on my taillights last time I had them out...they were GREEN/BLUE with crud.
okamikai
04-30-2018 10:19 PM
Doug4320
03-24-2018 10:11 PM
montanatruck
02-26-2017 07:07 AM
TDonkey
07-26-2015 10:14 AM
v_man
07-23-2015 04:01 PM
Quick Reply: Save me from a McGyver ground wire
