running rough/missing when warmed up
Old Dec 30, 2011 | 12:15 AM
notanymore's Avatar
to start off i have an 87 pickup with the 22re, when i start it up cold it runs smooth for a few minutes until it starts to warm up then it starts running rough and misses badly, without giving it gas it wont idle on its own.
i already changed the routine plugs/wires & cap/rotor with no improvement
i have exactly one week to get it running good enough to drive across the state and dont know where to start next
Old Dec 31, 2011 | 05:03 AM
tacdawi's Avatar
There is a very good sticky on this if you search "idle" in this forum. But I will suggest cleaning/checking the throttle body next.
Old Dec 31, 2011 | 05:32 AM
thook's Avatar
Throttle body clean (never hurts)
Idle Air Valve
Coolant temp sensor
Possibilities......in that order.
Old Dec 31, 2011 | 07:24 AM
Badger62811's Avatar
Have you done any work on it? Mine did that after my HG change, I had 2 vacuum hoses switched... Does it run smooth when you raise the RPM?
Old Dec 31, 2011 | 10:11 AM
abecedarian's Avatar
idle speed, timing, etc. are always set with the engine warmed up. take care of that and you'll only have to deal with a truck that won't idle well (maybe) until warmed up.
then you can fix the things that affect cold idle: idle air valve / auxillary air valve, cold start injector timing switch and cold start injector.
get it running well warmed up first then trouble shoot why it won't idle cold.
Old Dec 31, 2011 | 08:17 PM
thook's Avatar
Maybe I'm being a brickhead, but how does the cold start system affect cold idle? Do you mean under normal operation or in the event there's a malfunction that there's any effect?
ps. You need an avatar, Abe!
Old Dec 31, 2011 | 08:34 PM
alltracman78's Avatar
The CSI doesn't really effect cold running, other than MAYBE incidentally from any pooling fuel.
The CSI turns off the instant the starter loses power.
Old Dec 31, 2011 | 08:40 PM
Blacksmith's Avatar
I have a 86 22re turbo when this happened to me i had low compression in the head. I only i had one cylinder actualy firing and work properly. I had two choices rebuild head or the the core and i rebuilt the core.
Old Dec 31, 2011 | 10:21 PM
thook's Avatar
Oh, I know how it works. I was just givin' Abe a poke in the ribs.
Sleaker
Aug 26, 2020 06:03 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
Jonny246
Jul 12, 2015 04:51 AM
Kluch8651
Jul 9, 2015 10:39 AM
