How did you remove oil pressure sender for SR5 gauge swap?
Old 12-17-2011, 08:55 AM
Zelephant's Avatar
The darn thing won't come off! I started at a 24mm socket, then a 25mm, then a 27mm, which was too big. So then I tried a 1" (too small) and then a 1 1/16" (too big). How did you guys get this stupid thing off? There's no room between the engine and the frame to get a wrench or channel locks in there. When searching old threads, I found some ambiguous references to an obscure plumbing wrench that does the job, but nothing specific.
Old 12-17-2011, 09:05 AM
93YotaGuy's Avatar
I normally get it off with a channel locks. Have you tried going through the passengers side wheel well and removing the access panel?
Old 12-17-2011, 09:13 AM
paintthetown's Avatar
Did you get under the truck and look up at the unit. Take the black cover off and you should be able get a 14mm wrench in between the unit and the block. Hope that was what your looking for.
Old 12-17-2011, 09:18 AM
Zelephant's Avatar
That's what I've been doing. It looked like the only way to do it. I didn't even try going from underneath, I took it for granted the diff was in the way.
So, the old unit has the hex head on the back like the new one does? Did not know that. All the searching I did said you have to put a socket over the outside. I'll give that a try!
EDIT: Are you sure the DLX switch has a hex head on the back, because I couldn't find one. And I don't know if I know what you mean by "looking up at the unit". The diff is DIRECTLY beneath it, I have no idea how to get at it from underneath, but I'm open to suggestions.
Old 12-17-2011, 10:45 AM
Bassmastry101's Avatar
Go at it from the side..I couldn't get mine off with a wrench either...I had to use a big pair of channel locks and a little elbow grease.
Old 12-17-2011, 02:00 PM
Zelephant's Avatar
I'll give that a try tomorrow, but I gotta ask, do you have AC? Because the sender is flanked by the starter on one side and AC compressor on the other, I have to wonder if I'll be able to fit a set of channel locks in there.
Old 12-17-2011, 02:08 PM
Yes I have AC, It was a tight fit..Doing this might also destroy the sending unit since it bends the case a little. But it will get it off.
Old 12-17-2011, 02:13 PM
We need a pic
Old 12-17-2011, 02:41 PM
93YotaGuy's Avatar
Why not try and unmount the AC compressor from the bracket. It's about 3-4 bolts and you could push it out of the way to give you more room.
Old 12-17-2011, 02:45 PM
Zelephant's Avatar
A pic you shall have:
I marked the sensor in orange parenthesis.
Another factor I forgot about is the motor mount, that's in the way, too.
And I absolutely do not care if I destroy the sensor, so long as it comes off and doesn't snap off in the block.
Old 12-17-2011, 02:49 PM
93YotaGuy's Avatar
You could have probably done without the pic. Bass and I know what you are talking about although paint may not.
Old 12-17-2011, 02:51 PM
93YotaGuy's Avatar
Another thought,
It may give you a little more clearance with the pliers/channel locks if you unscrew the filter
Old 12-17-2011, 03:02 PM
Junkers88's Avatar
Strange. IIRC I did mine from underneath with an open ended wrench. I remember having to deal with the oil dripping on me while I installed the SR5 sending unit.
Old 12-17-2011, 03:03 PM
Take that bar off that goes from the intake to the motor mount. I never put mine back on..so that's probably why I had the clearance to take the stock sensor off.
Make sure you put it back on though lol
Old 12-18-2011, 05:10 PM
iamsuperbleeder's Avatar
it's much easier when the motor is out of the truck; just say'n
if I'm not mistaken though, I think I used an O2 sensor socket to get the original non-SR5 one off... I THINK... it's been a few years
Old 12-18-2011, 05:58 PM
Swimmerboy2112's Avatar
I did mine around this time last year, it was snowing, not fun...
Anyway, I removed the little access panes under the passenger fender and if I recall correctly, used a set of channel locks to twist mine off. Granted it did damage the old unit but I was ok with it since I obviously had the new sending unit.
P.S. I assume the cluster I shipped you made it up ok?
Old 12-19-2011, 04:20 PM
Zelephant's Avatar
Yep, it's installed in the truck now! Thanks again! Everything works except the oil pressure, obviously, and before anyone asks, I did NOT leave the stock sender plugged in. I have pics of it just before the install in my build thread, I'll upload more of the white LED backlight later.
I'm pulling 12-hour work days right now. Getting the old sensor out is gonna have to wait until Christmas Eve.
Old 12-20-2011, 03:25 AM
I have to say bleeder, that is one sexy engine. Makes me want to take mine back out so I can get crazy with some paint lol!
Old 12-20-2011, 04:00 AM
X2 with that sexy engine. I want mine in camo. LOL
streetuner15
06-18-2015 10:59 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: How did you remove oil pressure sender for SR5 gauge swap?
