what problems can a bad cat or muffler cause
Old Jan 2, 2012 | 11:58 AM
AZSPEED's Avatar
I have a 90 3.0 4runner that I just did the timing belt on, can't get it to idle smooth and when I try and do the timing anything below 15 deg doesn't want to run. the cat and muffler are bad and i'm wondering if there is alot of backpressure causing this problem. going to take a hacksaw to the muffler and see how it does
Old Jan 3, 2012 | 06:48 AM
Bassmastry101's Avatar
With mine the cat was stopped up pretty bad. My exhaust manifold was warped just a little bit and with all that pressure, I was blowing manifold gaskets and melting spark plug wires like you've never seen. Hacked off the cat and never looked back. (No Emissions here)
Old Jan 3, 2012 | 07:11 AM
93toyrunner2's Avatar
Have you unplugged your TP sensor to see if that may have anything to do with it? Was the truck running ok before the timing belt?
Charecter1
Nov 6, 2023 10:08 AM
Eggslinger
Jun 8, 2019 03:32 PM
Sep 4, 2015 09:27 AM
Poncho0206
Jul 10, 2015 06:21 PM
Kluch8651
Jul 9, 2015 10:39 AM
