Torque spec
Old Dec 29, 2011 | 08:14 AM
toda90's Avatar
Torque spec
Ive got a 91 4x4 sr5 that has a seal leaking from the front diff. I need to know what the torque spec is for the nut that holds the yolk in to the diff so I can replace the seal. Anyone know? Would 100 foot pounds be to much or not enough. I've looked on google and in the Manuel and have had no luck so far.
Old Dec 29, 2011 | 09:28 AM
waskillywabbit's Avatar
www.ncttora.com/fsm
:wabbit2:
Old Dec 29, 2011 | 09:38 AM
alltracman78's Avatar
89 ft/lbs, then check the preload on the pinion bearing.
It's supposed to be 10 - 16 in/lbs. If it's too little add another 9 ft/lbs to the nut, and recheck. Keep adding until you get the right preload.
If it's too high, you'll need to replace the spacer.
Old Dec 29, 2011 | 06:24 PM
toda90's Avatar
thank ya man
kawazx636
Oct 6, 2021 03:03 PM
83yotastockR
11
Nov 10, 2015 06:54 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Kamaloha
Oct 16, 2015 05:13 PM
Obmi
Oct 4, 2015 11:30 AM
