1990 4runner Oxygen Sensor
Old Jan 2, 2012 | 07:18 PM
ColbyJack's Avatar
So I picked up this 4runner a few months ago, my first toyota, for $800. I feel like I got away with robbery, I love this thing. It had sat for 5 years under a tree and didn't start, I had to trailer it and ended up changing the gas tank/fuel pump/alternator right off the bat and she was running great until recently.
Stopped for fuel one day and went to restart. The truck would crank as normal but would not continue to run unless I kept my foot on the gas pedal it would die. Other symptoms: the truck will shimmy and vibrate as if being turned on and off very quickly while Im going down the road and the check engine light will come on.
I pulled the check engine code as "oxygen sensor" So here are my concerns.
Will replacing the O2 sensor be the last of my worries? I know the 1990 has only one before the cat converter.
Also what other maintenance/tune up do you recommend for a vehicle that sat for that long.
Thanks for any advice.
Old Jan 2, 2012 | 07:20 PM
fork's Avatar
firstly what engine are we dealing with here
in what shape is the fuel filter in
Old Jan 2, 2012 | 07:22 PM
ColbyJack's Avatar
V6 3. Slow
Replaced fuel filter when I changed the fuel pump
Old Jan 2, 2012 | 07:58 PM
fork's Avatar
have you done any other maintenance to it? here's a link to the fsm to rule out the oxygen sensor http://www.ncttora.com/fsm/1993/engine/101heatedox.pdf (btw the entire FSM is available there if you haven't found it yet)
Old Jan 2, 2012 | 08:27 PM
thook's Avatar
Which O2 code did you get?
Servicing the injectors would be a very wise thing to do. It's quite possible they're atleast part of your problem. Of course, you could try some Seafoam or cleaner of choice, but sitting that long it may not do the trick completely. Pintle injectors do not like old fuel or sitting for long periods.
Hell, for that matter, it might be a good idea to get a professional fuel system flush and do the injectors.
Old Jan 2, 2012 | 09:50 PM
ColbyJack's Avatar
I followed these instructions and got code 5
http://www.troublecodes.net/Toyota/
Old Jan 3, 2012 | 03:07 AM
alltracman78's Avatar
Start with the O2.
There's no way of telling if there are other problems til you fix that and see how it runs.
Old Jan 3, 2012 | 05:15 AM
93toyrunner2's Avatar
Cap, Rotor, Plugs, Wires, Air filter, Oil change after running SeaFoam in the crankcase for 100 miles. Run a half can of SeaFoam through your intake system before you replace the O2 sensor. SeaFoam in the gas tank, 1oz per gallon of gas, to clean out the injectors while driving.
Old Jan 5, 2012 | 07:05 PM
ColbyJack's Avatar
Ok I picked up the O2 sensor and replaced it, and I'm still having the same problem! Still getting the same check engine code also.
What could cause the O2 code to keep going off after its been replaced?
Im going to replace the plugs, cap, rotor, wires but after that Im clueless.
Old Jan 6, 2012 | 07:07 AM
Wiring short. Grab your FSM, and start testing (check continuity) the wiring from the ECM to the O2 sensor. It runs down the drivers side frame from under the drivers seat area, and can get damaged. Check the wires all the way to the ECM for continuity.
Old Feb 25, 2014 | 12:50 PM
Jbowls's Avatar
Did you check the fuel pump fuse? Mine sat 5 years also and blew the efi fuse first time I filled the tank. I'm sure you fixed it by now this is old
Old Feb 27, 2014 | 10:54 AM
coloradotom's Avatar
EFI Fuse?
Is this a thing, does the EFI fuse blow very often?
Just now while home at lunch I was putting my EFI fuse back in, took it out this morning to reset the CEL. I really looked at it because it appeared that it could be inserted two different ways (180 degree rotation).
In another thread I described how I got a new O2 sensor, drove the truck about 120 highway miles, then had the CEL come on next time I got the engine up to operating temp. I took apart the connection to the sensor from the wiring harness and found some sloppy splices. Could have been shorting? Which could blow the fuse?
Will the truck run without that fuse? Does it truly control the EFI, because if so I would think the truck would fail to even start without a good fuse.
So?
Old Feb 27, 2014 | 11:10 AM
james92toy's Avatar
I'm thinking you need to check your timing also maybe a small vacuum leak or egr valve is stuck open a little .
Old Feb 27, 2014 | 11:58 AM
Gamefreakgc's Avatar
It will work either way, it's just a fusable link. Doesn't matter which way, it will hold the current.
Those sloppy splicing could most definitely cause a fuse the blow. Probably the main cause besides water damage for most blown fuses is bad wiring. The EFI fuse doesn't necessarily power the whole system, the injectors and such will still run if I'm remembering the wiring diagram right. I believe the fuse is just to the ECU, so without it you'll get poor fuel management and other issues.
Old Feb 27, 2014 | 01:06 PM
masterchiefhasayota's Avatar
So?
Yes, the engine cannot run without that fuse. Are you having a problem with it right now? If you are, I believe I could help alot. Mine just recently kept blowing. Worked on it for weeks, finally fixed it. Turned out that the wiring going over my fuel rail was melted. several wires were severed, and it was grounding out.
Old Feb 28, 2014 | 07:17 AM
Jbowls's Avatar
When my efi fuse blew my 4runner would not start at all, just my experience. It did this only once so far but I keep a glovebox full of fuses just in case now.
Old Feb 28, 2014 | 07:19 AM
Well if your o2 sensor is bad, that can lead to efi fuse blows. Same with a bad fuel pump, a bad circuit opening relay, ground issue in efi system, or a bad ecu, the mother computer.
Mine was a ground prob, as I said. Yeah, Keep extra fuses, just in case.
Old Feb 28, 2014 | 07:28 AM
Jbowls's Avatar
I'm almost positive mine was from this old 250k fuel pump. I haven't check fuel pressure to see yet but may be worth looking into for you if the problem continues after you fix the wires.
Old Feb 28, 2014 | 07:30 AM
Well that would make sense then. You're probably A-OK.
MMA_Alex
25
Apr 18, 2017 05:07 AM
madxman21
Jul 9, 2015 10:26 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
wilbertd
Jul 6, 2015 07:39 AM
ptb12
Jul 5, 2015 01:49 PM
