gear oil in the steering box?
Old Dec 28, 2011 | 06:19 PM
az_eaglescout_pilot's Avatar
just finished putting my steering box back together after putting new seals through the entire box...did it all with this link: http://128.83.80.200/TACO/box.html
however when i looked at the FSM it said that i should "replenish steering gear with gear oil" and that it takes 400 cc of it. is this truly necessary? i thought that ATF was the lubricant in the steering system. if i do need to put some gear oil in what weight? this was not mentioned in the link above, and im pretty sure he hasn't had problems with it.
Thanks,
Jordan
Old Dec 28, 2011 | 06:59 PM
DeathCougar's Avatar
Gear oil is used if you have MANUAL steering only.
ATF is used if you have POWER steering.
Old Jan 9, 2026 | 08:52 AM
earl.rogers's Avatar
steering gear lubricant
80-90 gear oil. ???? Is that what ‘s recommended for a 1984 Toyota truck with conventional steering gear box. Please advise
Old Jan 9, 2026 | 05:06 PM
JJ'89's Avatar
Yes. GL-4 at your hardware or auto parts store will be fine
maachine
12
Jun 14, 2013 09:07 PM
cap85
Apr 7, 2012 12:04 PM
TORTIS
Jan 11, 2012 04:14 PM
amusement
Dec 13, 2003 12:47 PM
