oil leak
Old Dec 13, 2011 | 05:37 PM
supergenius's Avatar
oil leak
Hi guys, I have a 3vze with an oil leak. It has new valve cover seals, cam seals, and main seals. The oil leak went from a shower of oil before to just a small stream now. It's coming from the passenger side about where the head meets the block behind the timing cover...approximately. There is no coolant in my oil, and no oil in my coolant. Anyone have any ideas before I go pulling it apart again?
Old Dec 14, 2011 | 12:08 AM
TNRabbit's Avatar
Pull the timing cover?
If the cam seals were replaced, you've obviously had the timing cover off. Can't think anywhere else in that area you'd have oil coming from ....
Old Dec 14, 2011 | 03:16 PM
rworegon's Avatar
When you re-installed the valve cover, did you place the seal packing i.e. oil resistant RTV in the spots indicated on page EG2-78, step 5:
http://www.ncttora.com/fsm/1990-1995...e/cylinder.pdf
Eggslinger
Jun 8, 2019 03:32 PM
Ladythump
22
Nov 9, 2015 08:53 AM
jakebarrett
Jul 10, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
87blyota
Jul 10, 2015 04:31 AM
