PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 [182] 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. I didnt know this was possible
  2. Can I clear 33's?
  3. Newb:Torsion Bar/ Lift Questions
  4. Ramsey Winch re8000
  5. Brake problems? Maybe this will help others with same issues
  6. 3.0 Engine problem/Question
  7. speaker help?
  8. 4runner drive shaft making noises
  9. removing A/C belt
  10. Wtb Bucket Seats
  11. winch and winch mounting
  12. Lifts.....Tires
  13. 3vze rebuild no start please help
  14. Upgraded (larger) exhaust = idle stumble on 22RE?
  15. Possible Hydrolock what to do
  16. Declining MPG
  17. 22r no fuel in sight glass
  18. Driveline Lubrication
  19. Marlin Crawler Rear Bumper
  20. 89 4Runner 22RE engine cutting out
  21. Backfire through intake and oil dripping frim intake
  22. Starting Problem?
  23. Back Window help
  24. Who's used 3" front springs?
  25. Now this one is interesting...
  26. mileage on 22re engine
  27. Helpfull info for 4runner
  28. Fuel Pump stoped working!
  29. Coolant In the Oil
  30. Work this wekend
  31. Pumped!
  32. Auto tranny issue only when heeling!
  33. Low Compression
  34. Mud Flaps
  35. Warped Head: Mill it or Replace it?
  36. Wierd Clattering Noise
  37. Push Bar/Brush Guard Installation Help
  38. need to know where to get a lot of parts and such
  39. forged pistons
  40. CV Axle Length??
  41. something blew (#2)
  42. A/T oil temp, Charge Light, and brake light come on 86 $Runner 22re 5spd swap
  43. A/T oil temp, Charge Light, and brake light come on
  44. 22r loud tapping (not chain)
  45. Needing to replace a bed
  46. Anyone go shroudless?
  47. oil pickup up screen 22re
  48. A340h Tranny Problems
  49. I would like to say THANK YOU...
  50. Spun rod or main bearing help.
  51. D rings...
  52. Boiling Radiator! OH-NO! Help...
  53. Just sold my running boards...WOW!
  54. Mileage boost from removing hardtop!?!?
  55. Need opinion on minor purchase...
  56. TruTrac Locker ?.
  57. plans for tomorrow...
  58. On gas ringing noise?
  59. rear window 87 4runner
  60. 1991 4runner popping noise from back
  61. Saying goodbye to the 4runner......with pic.
  62. Late model Rear View Mirror Fab
  63. Data link connector Location
  64. valve stem seals (installation of seal itself)
  65. Volkswagen Taro!!!
  66. Rake/biggest tire size 2wd
  67. over 50 vibration(yes i searched)
  68. need a pick up tube for canada fuel tank
  69. Toyota factory winch in 86?
  70. need help wont shift into 4 low
  71. 3.0L Rear Cam Plug Help, doing the work at this moment
  72. Something blew
  73. 1986 toyota 4runner passed enhanced cali smog test with flying colors, woooohooo!!!
  74. Why is my cat sideways, and what is this button to
  75. Hub Problem???
  76. I need help....
  77. T100 IFS on pickup?
  78. 4x4 engagement
  79. Cam Sprocket Bolt
  80. Clutch issues maybe?
  81. Who's taken the factory 20+ year decals off their rigs?
  82. finally getting my engine rebuilt.. GUIDE to parts/other?
  83. shocks for 92 4runner
  84. Digital Dash shorting out...
  85. Warn vs Aisin?
  86. Coils have to come out for Air Lift 1000??
  87. T bar problem?
  88. toyota wont start, completely dead
  89. Aisin Locking Hubs Tear Down/Build Up
  90. ??? How do you take out the top 2 17mm bolts on the bell housing??
  91. Huge Score Today
  92. dome light goes off and on.
  93. what gears do i have in my truck.
  94. roll bar measurements
  95. Cold start 1991 P/U
  96. parking break frozen
  97. 3.0 head gasket questions - help.
  98. Clutch job
  99. '85 22R won't kick down
  100. question on machining a chevy rotor
  101. Oil pan gasket and fan belts
  102. 86 Build up
  103. "Off Road" air intake
  104. 1st gen custom fr bumpers
  105. Denso 234-4052
  106. What GAS!!
  107. will these wheels fit over my hubs?
  108. oil presure guage/sensor?
  109. Farmington Canyon Utah (PICS)
  110. Dome light shorted out
  111. Something for the new folks
  112. Steering wheel help??
  113. Starting Idle
  114. hub conversion
  115. Help:Breaking the drive shaft nut loose
  116. Need some diagnosing help
  117. 3vze Head Source
  118. 22re Rebuild Follow along
  119. how many miles till highway driving?
  120. putting 22r in a 22re HELP PLZ
  121. pvc snorkle???
  122. Removing ADD
  123. cold performance problem
  124. h4 conversion or upgrade headlight harness
  125. quick question, parts interchange
  126. 5VZFE for sale - CHEAP
  127. Towing an 87 Runner, Advice?
  128. I got issues...
  129. Were can I get a Fuel Gauge sending unit (It's already a bad week here)
  130. Wheel size
  131. Volt / resistance of 3vze fuel gauge
  132. 87 engine no longer actin weird!
  133. New Parts...Eye Candy
  134. 94 4runner oil issues
  135. D.O.A. Cams
  136. Rebuilding
  137. H4 Head Light Conversion
  138. tweaked bvsv??
  139. Chain or strap?
  140. Injector question
  141. Exhaust for 550 bucks????
  142. 86 22re
  143. Daytime running lights
  144. Idler arm bushings
  145. transfer case low?
  146. Manual Hubs
  147. How much is too much to pay?
  148. Serious oil leak right after oil change
  149. guages???
  150. 5-speed swap half-way done!!
  151. Need advice ASAP!!
  152. Adding intermittent wipers
  153. My new truck?
  154. how much travel
  155. 3.0 rebuild engine paint question
  156. 95 4runner 4" lift going to 6"
  157. Spare tire holder..
  158. Front Bump Stops?
  159. wheeling and new tires
  160. breaks problems
  161. need trans help!!
  162. stupid question
  163. Auto Tranny help!!!
  164. headgasket
  165. Cold acceleration problem
  166. When do you stop building
  167. recall issues
  168. 22re knocking under load
  169. Old V8 Guy 1st time into 22re
  170. S-10 Zr2
  171. rear window..
  172. will this fit in an 89 4runner?
  173. clutch is soft 88 4x4
  174. Name this part
  175. Woohooo good news!
  176. Truck sat empty for a year, now wont start.
  177. flexible type steps
  178. Rough Idle When Warm?
  179. soft clutch pedal (but new clutch -toy oem)
  180. GREAT DEAL ON TIRES gotta love craigslist :)
  181. Custom Fab in Socal????
  182. Question on valve cover hose
  183. HELP!! Electrical problems!
  184. Front end..before and after
  185. My HomeStyle body work...
  186. True flow, K and N, Tornado, any thoughts?
  187. Rear shocks removal
  188. Drive train, front to back
  189. stalling problem.
  190. About to install BJ spacers....need advice..
  191. The 16k Run!
  192. Engine mechanical problem
  193. Newbie
  194. Catalytic conv
  195. Think i can run 35s??
  196. Advice/Help
  197. Head Gasket Sealant
  198. Open garage in St. Louis?
  199. mesh headlight guards
  200. oem roof rack lights?
  201. 22re rebuild or replace engine (Blown head gasket)
  202. 89 4runner harness for 86 4runner
  203. Another New Guy
  204. Taking Fuel Injector Assembly off
  205. Weird vibration and thrumming noise in my '92
  206. Do I have a Welded Diff?
  207. 22R Engine
  208. Electric Front Seat
  209. 33's now 35's later...
  210. bushwacker cutout flares 95 runner
  211. front diff
  212. Scubas Bucket seat Install
  213. Opinions On Detroit Trutrac Limited Slip.
  214. so I'm about to order my suspention parts...
  215. Check out this blown 22r that still runs
  216. anyone on wednesday, 11/5, have the day off in san diego?
  217. Idler arm & wiper motor
  218. Engine Surging
  219. What tires can I clear?
  220. High idle(22RE)
  221. Odometer not working
  222. Am I NUTS?
  223. Parts identification, Transfer case & Idler arm
  224. New Cluch and other things!!
  225. 22re running rough
  226. New radiator and it has holes!
  227. Rear brake weight adjuster thingy question.
  228. Any Shareware programs to check Yota OBD codes?
  229. rusty valve 3.0
  230. '86 still actin up..HELP!!?!?!?!
  231. 87 engine actin weird.
  232. truetracs and braking! fj80 coil FLEX!!! Breakage!!! 50/50
  233. Adding A/C to my 87
  234. smitybilt pipe bar set - Any welders in the area? (Victorville, CA)
  235. power loss, no acceleration problem, any help would be good.
  236. o2 sensor and smoke
  237. part interchanability
  238. Need FSM
  239. timing a 22re
  240. Fitting an OEM swing out spare tire carrier
  241. Newly Rebuilt 22re Wont start - - Help
  242. Hella e-code bulb choices
  243. More links to FSM's (Factory Service Manuels)
  244. HELP!!!!!! need advice
  245. NEED TECH HELP!!! Front end possibly ADD seeve???
  246. electric fan install
  247. 3VZ-E cooling system not circulating at idle.
  248. possibly grenaded front end today!
  249. Headbolt
  250. Random Question...
