Injector question
Old Nov 5, 2008 | 12:11 PM
Rocketwrencher's Avatar
Injector question
I just had my injectors tested and cleaned. Five flowed at 15 and one at 20 pre-cleaning. Post cleaning, the five that flowed at 15 went up to 17 and the one at 20 stayed the same. My question is, is this going to cause a rich condition? Should I replace the one or does it really matter?
Old Nov 5, 2008 | 02:43 PM
space-junk's Avatar
what company did you use?
these guys are top notch...
http://witchhunter.com/index.php4
check out their injector cleaning process... "After the foam settles, the results can be seen, these flowed to within 1%. "
Old Nov 5, 2008 | 06:23 PM
Flash319's Avatar
No. Mixture is controlled by ECU by monitioring engine sensors, most importantly the O2 sensor. Then it adjusts to achieve a 14.7 :1 mixture.
It does this by changing the time the injector is opened so the flow of the injector does not make a difference as the computer will correct for the flow change.
Old Nov 5, 2008 | 07:29 PM
abecedarian's Avatar
since the O2 sensor is not capable of responding fast enough to measure individual cylinder gasses and all 6 injectors are fired for the same duration, theoretically the one cylinder with the higher flow injector could run slightly rich while the others could be very slightly lean.
a ~15% difference in flow rate is not exactly a small amount- that one injector will inject approximately 15% more fuel for any given pulse duration than the other injectors.
Old Nov 6, 2008 | 08:45 AM
I had a guy in my town clean them. He only charged me $15.00 apiece. With the two opposing views on it running rich or not, it seems like I would be better off picking one up at the junkyard and having it cleaned for 20-25 bucks.
Old Nov 6, 2008 | 10:35 AM
space-junk's Avatar
or you could take them all back to the guy who cleaned them and have him re-clean all of them until they are within 1-2% of each other...
Doug4320
Mar 24, 2018 10:11 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
TJWilly
Jul 31, 2015 02:05 PM
pyramid
Jul 29, 2015 06:53 AM
