Think i can run 35s??
Old Nov 3, 2008 | 02:22 PM
Countryhick's Avatar
I have 33 12.50 15 Bfg A/T's i wanna run 35 12.50 15 Bfg M/t's
I have absolutely no rub. if you look at my pictures of my truck you can see i have like three or four inches of room to my finders in my front. i know my rear can clear it.
i have a 5inch ifs lift.
I'm thinking i can clear.
with maybe a little back fender cutting when you turn completely right. or left i think it might rub if i dont cutt.
Got any ideas?
Old Nov 3, 2008 | 02:50 PM
tc's Avatar
tc
Bracket lift is usually good for 35's, as you said, with minor trimming should definitely fit.
The big unknown at this point is the offset and backspacing of the wheels.
Old Nov 3, 2008 | 02:51 PM
1989toy4wd's Avatar
I think you will be good. I think a 4in you can fit 35s so a 5 def!!!
Old Nov 3, 2008 | 03:08 PM
Jay351's Avatar
Trim the lower valance a little, beat the pinchweld. You should be able to clear them. Will probibly rup under full crank and hard compression though..
Old Nov 3, 2008 | 03:10 PM
stagger_lee's Avatar
You should be alright. Like mentioned, some rubbing and maybe you could fix by doing a little pounding/hacking. Do you have a buddy with 35's to throw on and test fit? Make sure its what you want.
Old Nov 3, 2008 | 06:11 PM
AxleIke's Avatar
With that much lift, you should be able to fit 37's. Go for it.
Old Nov 3, 2008 | 06:15 PM
92yotaman's Avatar
my truck rubs in the back when really flexed, but its just a little rubbing and i have a 3in body lift, and a sas swap. so almost 5in lift
Old Nov 5, 2008 | 02:27 PM
934rnr's Avatar
Go for it just get be creative trim if you have to.
I ran 33's on my 93 4 runner stock then got a 1.5" BL did the cruiser coils and ball joint spacers.
I had enough room for 34's so 35's should be a problem in your case.
Old Nov 5, 2008 | 02:52 PM
olharleyman's Avatar
I have 35 x 12.5's on 3.75 back spacing with a 4" bracket lift and had to trim the pinch welds about 3" but still at full lock or compression have a slight rubbing issue with the under fender plastic 5" you should be good
Remove the valance trim the pinch weld from about 1" behind the wheel well and up to about half way up it if needed but with 5" of lift I don't think you will have the rubbing issue's I have with 4" of lift
It will still look good even better in my opinon , looks like this
Old Nov 5, 2008 | 02:54 PM
1986ToyTruckOMM's Avatar
You should be fine. With a 4 banger you might wanna regear but with a v6 your good.
the1998sr5
15
Jul 14, 2020 08:35 PM
Doug4320
Mar 24, 2018 10:11 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
toyoda8488
Jul 5, 2015 10:18 PM
