Name this part
Old Nov 4, 2008 | 09:30 AM
clayton_CJ7's Avatar
Name this part
I just was working on my truck and somehow managed to break what looks like a sensor or sending unit of somesort on the intake directly behind the upper Radiator hose, there are two of them there, one with a black connector and one with a green, it is the green one on the right hand side. if anyone knows what it is and where i can get it i would appreciate it.
Old Nov 4, 2008 | 09:40 AM
stagger_lee's Avatar
Probably would help if you told us what kind of truck/engine it is. Pics are always a plus too.
Old Nov 4, 2008 | 09:43 AM
MSR's Avatar
MSR
coolant temp sensor any auto parts store can help
Old Nov 4, 2008 | 09:47 AM
just a 22re's Avatar
x2 on the coolant temp
Old Nov 4, 2008 | 05:46 PM
abecedarian's Avatar
coolant temp.
cold start injector time switch is the other sender.
Old Nov 5, 2008 | 04:29 AM
I don't think it is the coolant temp sender because the guage still works and the check engine light came on, it is a 22RE
Old Nov 5, 2008 | 05:09 AM
saitotiktmdog's Avatar
Its the coolant temp sensor for the EFI not the Temperature gauge. The one for the Temp gauge is between cylinders 2 and 3 on the intake manifold. Or depending on the year may be on the thermostat housing I think. The two on the front there are for the efi and the cold start injector. Not for sure which is which though. Guess it would depend on how your truck runs now. If it starts worse you broke the cold start injector. If it just plain runs like garbage you efi sensor is probably the one you broke.
Old Nov 5, 2008 | 08:09 AM
Thanks guys, it does not start good when cold.
88sasturbotoy
Jan 30, 2026 01:57 PM
May 20, 2016 10:27 AM
Fundy Rider
Jul 16, 2015 01:35 AM
akaphilly
Jul 9, 2015 02:34 PM
