22re knocking under load
Old Nov 4, 2008 | 01:12 PM
Slowstrike's Avatar
Hey guys I searched and could not find an answer to my question. Here it is, My 22re has about 142k on I did the timing chain at 137k.
the noise is a metalic rattling is the best way I can describe it kinda like a timing chain but with more variation in the noise.
The conditions. It only happens when the truck is under load or bogging for power. For example if im in third going at lower rpm and shift to fourth and give it a good amount of gas the range before it hits powerband again it makes the noise and once it hits powerband the noise disappears.
Advancing the timing made the noise decrease or have less of a range to appear with the timing decreased the noise appears in the same but wider range.
any direction greatly appreciated.
Old Nov 11, 2008 | 10:51 PM
Bill54880's Avatar
Don't do that! Why would you shift to 4th if your at low rpms in 3rd and then complain of engine noise? Don't do it. It's bad for your engine. End of story.
Old Nov 11, 2008 | 10:53 PM
YoterUp's Avatar
thats beacuse its boggin out the motor cmon think about it! if it only happens then then DONT DO IT! if you cant drive a manual you can give it to me!
Old Nov 12, 2008 | 11:11 PM
abecedarian's Avatar
lugging / under-revving an engine can be just as bad as over-revving. there's not a lot of oil pressure/volume and the pistons can sqeeze the oil out of the rod bearings.
Old Nov 13, 2008 | 03:07 AM
RustBucket's Avatar
Have you checked a few obvious things?
1) Spark plugs are all in good condition, gapped correctly?
2) Valve lash is set to factory specs?
3) Ignition timing set to factory spec?
Old Nov 17, 2008 | 03:46 PM
Daniboy1994's Avatar
RE: 22re knocking under load
I have a 1991 22RE extended cab Toyota pickup, with the same problem. I think you have a bad rod bearing, & the piston is tapping the head. I also thought it was a bad timiong chain. Hope this helps. Dani.
Old Nov 24, 2008 | 12:17 PM
Slowstrike's Avatar
first off this truck is running 5.29s with 33s so maybe I illustrated the wrong picture when I said "bog". I go up hill in 5th on the freeway no problemo .
It is almost impossible to make this truck shudder from under rpm shifting. What I was trying to say was lower rpm or power range (I wish I had a tach I play it all by ear and feel)
Further I retarded the timing and the noise went away (I think I had it backwards in my original post).
The noise I was hearing seemed variable and well.... violent for pinging. Now the truck drags ass with the timing retarded. Im gonna mess with it and see where it starts to make the noise.
++ I hope not rodbearing
Old Nov 24, 2008 | 12:20 PM
what do you have the timing set at now?
Old Nov 24, 2008 | 12:26 PM
Slowstrike's Avatar
well to be honest I dont have a timing light yes there lies one of the problems
EDIT;(and no even tho I don't have a light it was not cranked up to 12 deg or something stupid ).
I think its around 7.5-8.5 currently, its idling normal just with slow pickup.
I dont think it will let me advance without the sound however and im running midgrade fuel at the moment 88 octane?
Old Dec 21, 2012 | 05:40 PM
Snortin Nortin's Avatar
It does sound like spark knock to me!! but I have heard on here that peeps are getting that on high test so I can;t say for sure? but ya sounds like that or your advance is getting messed up try high test and put it back to 5 degrees with te1 and e1 jumped make sure when u take jumper out that timing go's between 10-15 degrees !!
montanatruck
Feb 26, 2017 07:07 AM
Tacoma1313
Aug 17, 2015 05:44 PM
Cbr954ryder
Jul 25, 2015 06:32 PM
keithporter83
Jul 18, 2015 12:37 PM
Nickdigg
Jul 7, 2015 06:04 AM
