Wheel bearing? floorboard
Old Dec 19, 2012 | 09:04 AM
boggsu2's Avatar
I'm new to this forum and new to forums in general so bare with me. I have a 88 pickup and for about 2 months I have heard growling like my bearings are going out. When I turn right it goes away but its pretty constant if not louder when I turn left. I assume its my right front wheel bearings. Along with the growling the truck shakes too. Its not my daily driver so I dont have to worry about an immediate repair. If it is my bearings what brand do you recommend?
Also my driver floorboard is rusted through. Is there a website where I can order a new one?
Old Dec 19, 2012 | 09:28 AM
Sturmcrow's Avatar
A buddy of mine fixed his floorboard by welding in a flattened computer case. It seems any decently thick sheet metal will work. My dad and I fixed ours with fiberglass cloth and epoxy a couple of decades ago. It seemed to work pretty well until my bro wrecked the truck.
Old Dec 19, 2012 | 09:31 AM
boggsu2's Avatar
Hate to hear that. My biggest problem is at the bottom of the fender, where the the finder begins to roll. Also there is a small hole around my body mount. That is the main reason I want to get a complete one.
Old Dec 19, 2012 | 09:38 AM
96vettelt4's Avatar
when were the wheel bearings last done?
Old Dec 19, 2012 | 09:58 AM
atobe's Avatar
timken bearings is what toyota used on these trucks. Autozone carries them if you have it locally, or you can get them online.
Old Dec 19, 2012 | 10:15 AM
boggsu2's Avatar
As far as I know they have never been done. The truck has 147k miles.
Old Dec 19, 2012 | 10:16 AM
boggsu2's Avatar
Eventually I plan on lifting and running 33's. Will the timken bearings be strong enough to withstand the extra weight?
Old Dec 19, 2012 | 10:20 AM
waskillywabbit's Avatar
New bearings at dealer or online vendor.
Weld in new metal.
:wabbit2:
Old Dec 19, 2012 | 10:36 AM
snobdds's Avatar
This is not correct...
Nachi or KOYO are the OEM suppliers of bearings for Toyota.
http://www.marlincrawler.com/axle/fr...el-bearing-kit
Old Dec 19, 2012 | 12:38 PM
boggsu2's Avatar
So Nachi or Koyo is what I need to go with?
Old Dec 19, 2012 | 01:18 PM
snobdds's Avatar
You can go with whatever, but KOYO or Nachi is what came with the truck.
I have never had either one of these bearing fail...
Old Dec 19, 2012 | 01:21 PM
boggsu2's Avatar
Alright brother. Thanks.
Old Dec 19, 2012 | 01:37 PM
highonpottery's Avatar
i would personally clean, inspect, repack, and get the proper preload on the bearings before making the decision to outright replace. not a hard replacement either way.
Old Dec 21, 2012 | 05:50 PM
boggsu2's Avatar
I cleaned and replaced the front bearings. Pretty sure I didn't preload them properly. I don't have a spring scale or know what the tension is supposed to be. But it still isn't riding like it should. Could be the preload or axle bearings?
glowz825
Jan 25, 2022 09:28 AM
Sep 4, 2015 09:27 AM
Shaun Crystal Gomban
Aug 2, 2015 08:00 PM
RBK
Aug 1, 2015 01:55 PM
PlayAwhile
Jul 20, 2015 11:36 AM
