Welded front 3rd ?'s
Old Oct 30, 2008 | 11:09 PM
olharleyman's Avatar
Anyone have a good solution for a welded front 3rd? I have a welded 3rd in the 85 solid axle and don't want to have it welded any more so whats your best ideas for fixing it? I have 5.29's and would like to keep from replacing the the whole unit. i will be going to a e-locker soon but need to make it through winter first.
Old Oct 31, 2008 | 12:28 AM
EvaMonky's Avatar
Ummmm new gears? Isn't that pretty much the only solution?
I guess it would depend on how the welded it.
Old Oct 31, 2008 | 03:25 AM
crolison's Avatar
new spider gears
Old Oct 31, 2008 | 04:30 AM
WFO's Avatar
WFO
Unless they welded the gears to the carrier.
See if anyone wants to trade an open for a welded.
Old Oct 31, 2008 | 06:16 AM
waskillywabbit's Avatar
Welded fronts make turning terrible. Selectable is where it is at. Swap your welded 8" for an open 8". Shouldn't be too hard to find. If you just elded up the spider gears and not to the carrier too then just swap spider gears.
Old Oct 31, 2008 | 06:32 AM
AxleIke's Avatar
As long as it is only the spider gears that are welded, simply remove the third, buy another differential, remove the welded spider gears, and put in the new ones.
As long as the weld job was done reasonably, and isn't some abomination, it should take you a day or so on the weekend.
I suggest visiting Zuk's site for info on removal of the spider gears:
www.gearinstalls.com/v6lockrite.htm
The process is the same, just instead of a lockright, you put in unwelded spiders.
Old Oct 31, 2008 | 08:51 AM
ZUK's Avatar
ZUK
If I understand your question, Harleyman, then maybe you need a new CASE(4- cyl model? with 1 crosspin?)....just swap the carrier bearings over and ring gear and set BL and CBPL to the same spec as before. Then it will be as good as gold. I have a spare case if you can't find one. ZUK
Old Oct 31, 2008 | 09:32 AM
904_runner's Avatar
I have the spider gears out of my v6 case when i put my lockright in.
Old Oct 31, 2008 | 10:09 AM
TOYOTA 1's Avatar
those are different than a 4 cyl.
Old Oct 31, 2008 | 08:11 PM
Yes 4cyl. and I may need the carrier if so I will get hold of you thanks for the offer
Don't think they will work but thank you just the same
Not sure how bad or good the weld is it's from the truck I got from your neighborhood in ALABAMA maybe you talked with him and gave him an idea on how he should weld it? After all you sold him all the SAS stuff
Originally Posted by crolison
new spider gears
I figured that much but was just wondering the best and easiest way to go about it
Old Oct 31, 2008 | 08:39 PM
dropzone's Avatar
Fossilized
I am pretty sure I still spider gears and a cross pin (out of my '81)if you want them, just pay shipping..I think USPS has a flat rate box for around $8-9...
Old Oct 31, 2008 | 09:16 PM
If you find you have them still let me know and I will paypal you the shipping that would be great. I know USPS has a couple flat rate box deals so let me know.
Old Oct 31, 2008 | 09:20 PM
dropzone's Avatar
Fossilized
I am at work right now but can check when I get home in the morning and let you know...
Old Nov 1, 2008 | 12:29 AM
EvaMonky's Avatar
Aww isn't that what driving a Toyota is all about?
Old Nov 1, 2008 | 02:59 AM
dropzone's Avatar
Fossilized
hmmmm, I guess working a 12 hour night shift to support my Toyota habit might be what it is all about in some fubar kind of way
Old Nov 1, 2008 | 05:18 AM
You should have called me about that truck cause I know everyone in Alabama with a Toyota 4x4.
My guess is that it is welded properly and well as I know they have built several Toyotas and lots of off-road trucks.
Have you opened the diff up yet to look? You can probably pick up another 8" open diff for not much. They are on my local board all the time. Full set of 850 Toyota axles went for $300 last week.
Old Nov 1, 2008 | 09:01 AM
No I have not opened it up yet I have been rebuilding my Harley Motor and trying to get everything lined up to rebuild the motor on the truck I just want to get an idea of what I will need to do to fix the welded front when I get to finally get to doing it I plan to be driving it by Christmas welded or not just trying to get a heads up on what will be easiest to do for the front.
Old Nov 1, 2008 | 05:05 PM
dropzone's Avatar
Fossilized
I found the spider gears but braincramped the cross pin, Guess I ended up using it. If you still want the spider gears how about $6 to ship them to you.
88sasturbotoy
Jan 30, 2026 01:57 PM
jasonty
41
Dec 23, 2018 01:00 PM
jerusry
Oct 19, 2015 05:28 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
crashburnoveride
Jul 10, 2015 06:39 AM
