I got issues...
Old Nov 5, 2008 | 06:03 PM
toyospearo's Avatar
I got issues...
I just did an IFS Job on my 94 ext cab 4x4, NEW CV's, Rancho shocks, TRE's, ball joints (upper and lower), as well as the sway bar bushings. I took the thing in to have it aligned and the mechanic told me the LCA bushing's were fine. I had asked him to look at the UCA bushings and he told me "I forgot to look at those." After installing the sway bar bushings this morning I took my rig for a 2 mile pot hole ride. The clunking, pounding sound was still there as evident as ever! At this point I am at a loss for what is causing this. It is in my humble opinion the clunking sound is coming from the bump stops or the UCA bushings. I am not sure what else it could be
My issue is I don't want tear the UCA apart, take it out, press in the new bushings and all that to find out they are not the problem.
Any input on what is going on here would be much appreciated!!!
I couldnt find a distributor for 94 4x4 extended cab bump stops. A link to order a set would be appreciated. I figure I may as well change those.
thanks
Old Nov 5, 2008 | 06:37 PM
DeathCougar's Avatar
Have you looked at your Idler arm? I had the same problem, and my idler arm was worn beyond belief.
Old Nov 5, 2008 | 06:39 PM
toyospearo's Avatar
I just replaced it and the pitman arm a month ago.
Old Nov 5, 2008 | 06:40 PM
904_runner's Avatar
EDIT: NVM
what do the uca bushings look like?? all visibly good?
toyospearo's Avatar
I just replaced it and the pitman arm a month ago. The clunk is more noticeable on the drivers side (louder.)
Old Nov 5, 2008 | 06:58 PM
Trustyrusty's Avatar
SAS......
Old Nov 5, 2008 | 07:02 PM
toyospearo's Avatar
Originally Posted by Trustyrusty
SAS......
Dude... seriously, I am looking for a 79 - 83. If this PU wasn't my DD I would be out there in the cold rain with no garage SASing that thing as we speak!
Old Nov 5, 2008 | 07:05 PM
904_runner's Avatar
Where do you live in nor cal? ive seen some sfa floating around on other boards
Old Nov 5, 2008 | 07:12 PM
abecedarian's Avatar
you might be overextending the shocks... are the new shocks long enough or shimmed to accomodate the extended lower arm travel provided by the ball joint spacers? it's mentioned on sdori's and 4crawler's installation instructions.
I looked at your write up and didn't see any photo or mention of it.
Old Nov 5, 2008 | 07:16 PM
toyospearo's Avatar
well, I took that into account. However, this issue with the clunking was going on before I installed the new Rancho shocks or any repair on the front end for that matter.
Old Nov 5, 2008 | 07:21 PM
toyospearo's Avatar
I am having trouble finding Sdori's or 4crawlers installation instructions on this . Could you link me up please??
thanks
Old Nov 5, 2008 | 07:31 PM
thanks
http://www.4crawler.com/4x4/ForSale/...er_HowTo.shtml
http://www.sdori.com/SDORI_4WD_Spacer_Install.html
Old Nov 5, 2008 | 08:00 PM
toyospearo's Avatar
Humboldt
Old Nov 5, 2008 | 08:01 PM
904_runner's Avatar
oh.
Sorry haven't seen anything up there, mostly in the chico area
Old Nov 5, 2008 | 08:05 PM
toyospearo's Avatar
EDIT: NVM
Being that I don't own a front end repair shop nor do I do UCA and LCA repairs on a regular basis I am not sure how to determine what is "visibly good." What should I look for? Is it possible to tell if the hardware inside the sleeve is good or bad? I have looked at the LCA bushings and the UCA bushings and it is difficult to tell if they are bad or good. Unless there is something I am not seeing.
thanks!
Old Nov 5, 2008 | 08:17 PM
904_runner's Avatar
Well, i would look and see if they are all still there for starters. then look and see if they are cracked or not.
Old Nov 6, 2008 | 12:31 AM
ovrrdrive's Avatar
Wow that sucks...
Sure it isn't the swaybar or anything simple?
If it is the UCA bushings, you're in for one hell of a job to get those out. You have to remove the tbars to do it, as well as the spindles. You might be able to leave the spindles hooked up but they'll flop out on you and ruin the CV's if you're not careful.
Have you tried walking beside the truck while someone drives it over some bumps to see if you can hear it?
Also, make sure your body mount bolts are tight. I had a noise from one of those once too.
Old Nov 6, 2008 | 02:51 PM
toyospearo's Avatar
spent a few hours under the thing today rattling around making sure everything was tight. Nothing moving, nothing visible. On the shock one of the rubber shock bushings was below the metal washer down in the rubber sock. I dont know how that happened.
New sway bar bushings look good. I suppose I will have to take the thing in to have an "expert" look at it. I cant figure it out. Any more input would be great!
I might do my rig like the one below. That would fix it for sure.
Old Nov 6, 2008 | 02:59 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
talk 'bout a Trailer Queen.........
lol
Team420
Jan 12, 2021 04:57 PM
cbono2000
Mar 29, 2015 03:51 PM
CajunTRD
Mar 19, 2014 06:59 AM
iamsuperbleeder
Aug 8, 2008 10:02 PM
YotaFun
21
Dec 2, 2006 08:23 PM
