Daytime running lights
Old Nov 5, 2008 | 07:51 AM
girlcrazy_4's Avatar
I have a 1990 2door runner and it does not have daytime running lights. Is there an easy way to wire this up??
Old Nov 5, 2008 | 07:58 AM
scuba's Avatar
turn em on when you get in....
Old Nov 5, 2008 | 08:19 AM
space-junk's Avatar
i guess you could find the wire that turns the lights on and wire a constant "on" to the ignition, kinda like your stereo... but its just easier to spin the switch... why do you want DTRLs??
Old Nov 5, 2008 | 09:03 AM
scuba's Avatar
x2...thats what im thinking..
I just turn on my marker lights when i get in..
To each their own..
Old Nov 5, 2008 | 09:48 AM
Matt16's Avatar
You probably need the little control box of a truck with DTRL that sits under the ash tray.
It would be a lot easier to just turn on your lights I think.
Old Nov 5, 2008 | 01:20 PM
sh0kk86's Avatar
maybe hes in canada and needs it to pass inspection?
Old Nov 5, 2008 | 02:13 PM
Noltz's Avatar
I put these in any US-spec cars that are being imported and do not already have daytime's.
Canadian Tire sells 'em for $40. Hooks to your battery and ground, two outputs (marker lights and headlights, or L & R headlights for European cars w/separate circuits). About 90 mins for a clean install. Uses a wire that wraps around a plug wire to detect the engine running, then turns the lights on about 4 seconds after startup.
Or, I'll run a Bosch relay under the dash that mimic's turning the headlights on as soon as the key is turned to "RUN". For cars with Coil-On-Plug ignition, this is easier.
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
Johntom240
7
Jul 13, 2015 12:18 AM
madxman21
Jul 9, 2015 10:26 AM
