PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 [118] 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266
  1. Pinging cure!
  2. Distributor making new hissing sound
  3. Once again my 3.0 wont start
  4. 89 wiper arm: interchange with others?
  5. High pitch sound when starting cold !!!
  6. 1992 Toyota Dually(automatic) question
  7. 1989 22re Vacuum Question
  8. Why can't I find a e-brake cable that will work?
  9. truck starts up warms then dies?
  10. alternator upgrade help
  11. Front hub spinning axle when in FREE select.
  12. What is This part
  13. Rear Spring Bushing Help
  14. HELP!!! check engine light and RPM'S drop!!
  15. ct26 turbo question
  16. Downey headers-no crossover=dual exhaust?
  17. Frame Rot Repair (Lots of Pics)
  18. RathDeal19 1988 Toyota Pickup v6 Build Up
  19. Need help with my speedometer!
  20. Help me find the correct radiator cap: Aftermarket Radiator
  21. Lost the "hidden bolt" during head swap
  22. Pickle Forking the Steering Stabilizer
  23. 95 4Runner jack and crank.
  24. Slowly sorting out the Electrical issues
  25. Strange brake issue, 89 4runner.
  26. Disable Auxiliary Air Valve?
  27. rattling when started
  28. Shouldn't I have an idler arm on my 1st gen?
  29. Temp rises/falls on how I drive. Buncha questions (t-stat, fan clutch, e-fan swap)
  30. 88 runner, auto trans, have to shift manually
  31. 1993 W56 transfer case on a 1990 W56?
  32. 2 WD Leaf Springs Sagging. Options?
  33. 94 22re Engine Trouble
  34. Relay rod
  35. 3vze Knock sensor wire
  36. 3VZE chugging, not leveling out on idle.
  37. Will replacing timing chain/cover fix or do I need to rebuild
  38. Fastest way of installing front lower ball joint!! WRITEUP!
  39. My truck just died
  40. Cup holder replacement 1992 Truck
  41. Engine dies
  42. annoying mystery grinding starter only when it's cold outside
  43. GPS as a Speedo?
  44. does anyone have 6 spare torque converter bolts for a 3vz a340?
  45. Which fuel pump ?
  46. powersurging/battery draining/fuel gauge rising
  47. TPS question 22re
  48. question about rear anti lock?
  49. Losing Oil. Rings?
  50. Aisin help, took the new to me yota in the shop, came back with no good work
  51. Check Engine Light Burns Lots of fuel (MAF?)
  52. Break-in Protocol
  53. spring-under axle?
  54. Car seat in an Ext Cab? Safe? Legal? What's your opinion?
  55. Quick Question about Rear-end
  56. RPMs good, but no power
  57. home made shift knobs! what you guys think?
  58. P/S idle up solenoid
  59. Maybe a belt squeal?
  60. 22rte to w56???
  61. depress pass. window switch, window does not roll down, radio cuts out
  62. idle issues
  63. heater help
  64. SR5 Cluster swap...how hard?
  65. junk yard upgrades
  66. front suspension lift question (pick up)
  67. timing spec for 86 22rec
  68. Hard/non starting 22re in 87 4runner...fixed
  69. gauge problems
  70. help On adding power steering to 87 Pickup!!
  71. 3VZE Swap
  72. water pump q
  73. Odd noises and it seems like I'm losing power
  74. 3rd speedo gear failure?
  75. 1994 Toyota truck 2wd suspension rebuild help
  76. odd overheating issue with no in cab heat.
  77. 22RTE Starts then dies
  78. GEAR HElP!!!
  79. Locker Qusetions
  80. installed hids
  81. My 94 replacement truck
  82. 22RE Knock Sensor Bypass Harness Connectors
  83. Transmission wont hook back up to the engine.
  84. Tcase Front Output Noise
  85. 4x4 shifter knob
  86. 3VZE fuses
  87. Throttle Body Will Not Close Completely
  88. WOW Transfercase Flange Nut
  89. Master Cylinder Problems
  90. NOT Head Gasket but PISTON FAILURE!!
  91. 91 SR5 Pick-Up Radio "Stock?" Swap - Write up and Pics
  92. The quick and dirty Supra AFM swap
  93. Attempting 25MPG w/ my 22RE
  94. Rear Spring Decision
  95. having a WEIRD starting problem
  96. Roof Rack Options for Pickup Truck
  97. ENGN Builder Street RV Head
  98. How well should the EGR seal? 22re
  99. Can anyone help me identify this engine noise?
  100. Can't find FSM - Need help testing Oil Pressure Gauge
  101. camber in front two wheels WAY off
  102. Trouble starting and surging on start up.
  103. Upside down headgasket symptoms?
  104. 95 4Runner 3VZ A/T 4x4 MAJOR Power/MPG Issues
  105. Sheared my hub bolts/studs
  106. blown head gasket from misinstalled TPS?
  107. 3vze dying after starting, just replaced alt
  108. Oil in breather tube (3VZE)
  109. loss of power and mpg bad!!! need help
  110. auto tranny shifting issues
  111. 86 runner od question
  112. Ball Joint Replace Photos?
  113. Lost reverse after changing trans solenoids
  114. Advanced the timing 3 Degree's
  115. hesitation on cold startup '93 v6 3.0
  116. 3.0 Intake build idea...
  117. Tubbing 2nd Gen 4runner
  118. 1994 4runner no start
  119. possible 4x4 problem?
  120. grinding noise possible wheel bearing
  121. Low Compression and Timing off. More details inside help!
  122. 1986 Pickup where to buy a right side frame rail and how to replace
  123. Distributor help
  124. Dash/ac lights
  125. loping idle, no power, 14 miles on a fresh rebuild?
  126. fuel pump questions
  127. 95 4runner ignition stuck...
  128. My solution to vacuum switching valves (pic)
  129. 3vze Power Steering Pump nightmare!
  130. front cv long shaft part number
  131. 87 Runner Steering should I replace it?
  132. Replace radiator and fan clutch
  133. 1991 22re lack of fuel pressure....
  134. couple ofi nstrument panel LEDquestions
  135. Cross over re-route, good idea?
  136. Burnt Valves...How far should I go??
  137. 22r motor rebuild kit
  138. Changing W56 Input bearing
  139. speedo off
  140. 1992 22re Pick up Started to lose power lost all poer now will not start any Ideas?
  141. Transmission cooler question
  142. List of seats for bench conversion
  143. 22re helpppp
  144. question about the camshaft sprocket...holding in place while removing head
  145. 1990 22RE erratic idle
  146. Will this front diff fit my truck????
  147. 91 3.0 Wont start after alt install.
  148. 82 Supra AFM on a 3vze airbox
  149. removing crank bolt
  150. Leaking antifreeze
  151. Help with clock wiring
  152. flat towing question
  153. Distributor timing issue
  154. high idle on my way to work.
  155. 94 22re motor And trans replacement
  156. Front wheel bearing, adjustment or replace?
  157. Supra turbo on 22re!?!
  158. Electric fan conversion !
  159. 95 weird electrical problem
  160. Moogs in my rear!
  161. Pittman/ Idler arm needs replacement
  162. What is the best / proper off the shelf ATF for a high mile AT?
  163. Bodyman help
  164. Alternator issues after brush replacement!
  165. 3.0 Blown Headgasket - ???
  166. Drivetrain Length Comparison?
  167. Break in process - quickquestion
  168. Advice on Downey T-bars
  169. AAMCO semi synthetic ATF, anyone know where to buy it these days?
  170. 22RE Thermostat Replacement
  171. Speedometer Question
  172. 4runner cant hold idle and dies
  173. Excessive rattle
  174. stiffer torsion=less flex??
  175. running rough no power under load
  176. electric fan options
  177. Need intake help
  178. electronic torque wrenches
  179. 91 runner- 2wd front bumper on a 4x4?
  180. question about an HID 10000k conversion kit on a '93 toyota
  181. How loud is the blower supposed to be?
  182. Electrical ignition advice needed 22re
  183. '88 4Runner - Battery drains after new alternator installation!!
  184. Start UP
  185. Transfer case with electronic speedometer setup swapped into mechanical speedo truck?
  186. Vibration in 95 4Runner
  187. Something other than a headgasket?
  188. automatic transmission 3.0L reviews?
  189. What supra parts will work for us?
  190. Body parts, "replacement" or OEM $$
  191. Has anyone painted an entire ifs 4runner with bedliner???
  192. Difference between SR5 and EFI 4runner
  193. Electrical Gremlins
  194. Best 4-Runner Accessory source?
  195. battery light on, alt seems okay.
  196. Markers not working
  197. Starter wont disengage? keeps spinning?
  198. alty compatability ?
  199. Code 52
  200. 91 v-6 motor woes...
  201. mystery smoke: steering column on 1st Gen 4Runner
  202. Head gasket 89 pu
  203. Oil in valve cover front holes
  204. Duuuuuudes, check out how RAKED my truck is!
  205. 88 PU EFI Fuel pump bad? Please help. (Yes i'm searching as we speak too)
  206. fire in #1 hole...
  207. Whoops... Exhaust issue... aggrivated. Help
  208. CS130 Install in 1991 3.0 4Runner
  209. code 14,52 help
  210. 92 4runner hard starting, and yes i searched my butt off!!!
  211. wondering what that canister was that got lost?
  212. High Idle and Fluctuating Temp Gauge
  213. Good compression AND blue exhaust smoke?
  214. 1987 22r Carb developed sudden miss and loss of power
  215. Curt Trailer Hitch Mounted Spare Tire Carrier? work on 2nd gen?
  216. 86 4runner DRINKING OIL
  217. how to get better mpg with winter fuel??
  218. K&n valve / flap stuck open...
  219. 91 4runner diff questions.
  220. 22RE Will Not Turn Over!
  221. Best way to mount a roof rack on a 1st 4runner?
  222. IFS front end-Help
  223. '92 3VZE won't pass emissions, where should I look?
  224. 3vze pinging/knocking? timing issue?
  225. o2 sensors
  226. exhaust question
  227. 22re loss of power, sluggish
  228. aisin hub turns to lock cv's dont engage
  229. O2 Sensor 22re vs 22rte
  230. Leaking TVV valve?
  231. 22R knocking in the top end type of noise
  232. Toyota Truck dimmer problem ?
  233. Help with ground location on 3.0
  234. 1988 4runner intake tube?
  235. Code 25 & 26
  236. Has anyone ever seen this much carbon build up in the intake?
  237. 3.0 rebuilt engine install questions
  238. 3.0 "cuts out" for a split second?
  239. Bumper choices for 88 Pickup?
  240. 86 22RE spun rod bearing
  241. 874runner W56 transmission issues
  242. 22re Overheating really quick
  243. Idle compensator valve missing on carburetor
  244. 93 3.0 runs rough, sputters and dies when off gas
  245. water temp sensor, I found a new one in the garge, should I swap it?
  246. new 3.0 thermostat, is it the right part # 90916-03079 ???
  247. '94 Pickup No Power, Terrible MPG
  248. 89 t4r 22re 5spd...locked up after timing components replacement
  249. Water temp Sender
  250. side draft carb on 3vze & 22re
