Duuuuuudes, check out how RAKED my truck is!
Old Jan 11, 2011 | 08:33 AM
Magnusian's Avatar
From: Downtown Heckronto, Ontario, Soviet Canuckistan
Click for bigger.
Frame rot.
Body rot.
This is the driver's side floor, that patch is riveted on too, the floor support is cutoff just beyond where it passes the x-member.
Other side of of the patch. Can you see the line of rivets? (You can't, they're not there anymore) Notice how my wheel well IS SOLID, HAHAHAHAHAHA.
Old Jan 11, 2011 | 08:44 AM
iamsuperbleeder's Avatar
I'm so glad I live below the salt belt...
I have to be honest though; when I read the title, by "raked" I thought you meant a lowered front end and a higher rear end
Old Jan 11, 2011 | 08:49 AM
Magnusian's Avatar
Well, right now the nose is about 6" off the ground and the rear of the frame is about 4' in the air. Raked via jack stands.
Old Jan 11, 2011 | 08:53 AM
xxxtreme22r's Avatar
Magnusian, you can set photobucket to resize your photos to 1024X768 then all you have to do is use the img links.
Old Jan 11, 2011 | 09:21 AM
Magnusian's Avatar
True, but it already scales them down from 3072x2304 to 1,737x1,303. At the original resolution they are not the crispest shots as I cannot hold my hands completely still and I feel that they're too blurry if it scales any smaller.
Old Jan 12, 2011 | 12:49 PM
Magnusian's Avatar
e: nm, found thread that says nobody makes them.
MRael
19
Jul 13, 2002 08:54 AM
jacksonpt
Jun 17, 2002 09:47 AM
