3rd speedo gear failure?
Old Jan 19, 2011 | 05:52 AM
mldave's Avatar
On my 86 22 RE 4x4 truck..a new gear on the speedo cable has failed.The latest one worked for two weeks and now works intermittantly.The plastic gear gets chewed up .Guess the fellow putting them in is doing something wrong.It's the right OEM part number.Any opinions?
Old Jan 19, 2011 | 06:37 AM
dropzone's Avatar
Fossilized
Which end is failing: cluster end or Transfer case drive gear?
Old Jan 19, 2011 | 06:43 AM
mldave's Avatar
Not mechanical,but it's the yellow one with the splines
Old Jan 19, 2011 | 01:47 PM
meswoleshane's Avatar
I just went through this. One of the needle bearings in my transfer case was gone and chewed up all the gears in the case... The output flange had a lot of wobble and the seal began to leak. I just swapped in another case. When I pulled the bad one apart to switch shift rails (top vs. front) The speed-o gear and the oil gear where pretty much ground down to nothing. They chewed up the tail housing too. All the movement inside of there kept eating the speed-o gears.
smthwsn357
May 1, 2024 07:28 AM
Dieselmann
Feb 19, 2019 02:57 AM
mskalmus
May 28, 2017 07:51 AM
jerusry
Oct 19, 2015 05:28 PM
HollieJayyy
Aug 9, 2015 07:59 AM
