Pickle Forking the Steering Stabilizer
Old Jan 22, 2011 | 02:50 PM
noble's Avatar
Unhappy Pickle Forking the Steering Stabilizer
anybody have any suggestions on how to get the steering stabilizer out? I pickle forked, I hammered, I yelled, I cried, I prayed... And the stupid thing still wouldn't pop out... any better way than unhooking my entire steering to get it out?
Old Jan 22, 2011 | 02:57 PM
noble's Avatar
and there is no way there is room in there for a puller... There anybody? haha
Old Jan 22, 2011 | 03:01 PM
iamsuperbleeder's Avatar
I'm assuming the stock stabilizer?
if I remember correctly, mine popped out after a few wraps with a hammer. but then again I live below the rust belt, and the oil slung all over it from a front main seal for the previous 3 months might have helped a little too, LOL
I think I recall some people using ball joint remover tools with them, though I'm not 100% sure
Old Jan 22, 2011 | 03:12 PM
barrel roll's Avatar
I heard a torch works, too.
Old Jan 22, 2011 | 03:14 PM
xxxtreme22r's Avatar
Gonna guess your having issues with the relay rod side rather than the frame side? I had to use one of these to get it out:
http://www.napaonline.com/Search/Det...96_0006537798#
Old Jan 22, 2011 | 04:10 PM
scope103's Avatar
This guy (48811)?
Are you sure you're talking about the stabilizer? That's just held in with a long 12mm bolt through some rubber donuts. Getting it out isn't usually the problem; keeping it in can be.
Could you be working on the relay rod? You'll need a puller http://www.harborfreight.com/tie-rod...ller-1752.html Don't use a "pickle fork". Those are strictly for, well, amateurs.
Old Jan 22, 2011 | 04:15 PM
Marc's Avatar
This worked for me.
Old Jan 22, 2011 | 05:36 PM
highonpottery's Avatar
if you've got the pickle fork already, use your man hands, a BFH, some penetrating oil and maybe some heat.
Old Jan 22, 2011 | 06:13 PM
vital22re's Avatar
totally a bro
A hammer has never failed me for supsension work. You just gotta hit the right spot.
Old Jan 22, 2011 | 06:19 PM
aquaprice's Avatar
On my 94 I cut it off & drilled out the rest.
Old Jan 22, 2011 | 07:35 PM
ROCK LIZARD's Avatar
I see you have a '95, but on my '84 the stock stablizer bolt is a tapered bolt that is drawn into the hole on the tie rod when you tighten the nut. I had to cut off the large end of the bolt, then drill out the innards (like aquaprice). This was after hours of trying BFH, propane torch, pickle fork, and lots of 4 letter words. I used a hacksaw to cut the bolt, then use progressively bigger drill bits to hollow out the inside of the bolt. Took some time but it worked. TIP: when you install the new one, be sure to glob on some thread dope on the smooth taper to prevent this the next time you want to change out the stabilizer.
Good luck.
Old Jan 22, 2011 | 10:41 PM
SUPREHATER88ER's Avatar
More hammers!!!!!!!!!!!!!!!!!1
Ian
Old Jan 26, 2011 | 10:46 AM
noble's Avatar
finally got it out, left it sitting there for a few days, making the truck think about how hard it was making my life... I think when it saw me coming out into the lot with a bigger meaner hammer and an angry look and it decided to play... Took quite a bit of pounding, but finally popped out... Sigh..
And scope... steering stabilizer/steering damper is what I was beating on... Thanks everyone
Old Jan 27, 2011 | 12:51 AM
wyoming9's Avatar
Red face
I can only guess my day is coming I have never had an problem getting them out. Nor the bolt on the crank pulley Kroil must work.:jessica:
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
live4soccer7
May 11, 2016 06:52 PM
scott90
Oct 4, 2015 09:21 AM
ktm192k
Oct 1, 2015 08:47 AM
