3VZE Swap
Old Jan 19, 2011 | 07:59 AM
red4Runner91's Avatar
3VZE Swap
I Have a quick question. Does the 3vze fits bolt-ons in a 4 cylinder 4 runner 1991 4x4?
Old Jan 19, 2011 | 08:24 AM
blake.nemitz's Avatar
nope the bell on the tranny is way different and the wrong depth. youll need a v6 drivetrain or a turbo tranny with a v6 bell on it
Old Jan 19, 2011 | 07:34 PM
Ok but if i take the V6 drivetrain does the motor mount will fit bolt on under the hood ?
Old Jan 19, 2011 | 07:44 PM
sebastianholmes's Avatar
if youre gonna swap a motor may i ask why you want the 3.0? if it was me i would keep the 22r but if youre going through the trouble of a swap there a soooo many better choices. just my 2 cents
Old Jan 19, 2011 | 07:46 PM
Tofer's Avatar
Sponsor
agreed... 3,0 swap is a horrible idea.
how so ?
Old Jan 19, 2011 | 07:50 PM
try searching. theyre gutless, horrible gas mileage, prone to headgasket failure. get a 3.4L v6 from, i believe, 95 and newer toyotas. sooooo much better of an engine! again, use search!
Old Jan 19, 2011 | 07:53 PM
my dad has a pick up sr5 91 v6 and the gas mileage is not so bad it has 373k kilometers on it and runs still very good. never had many trouble tho
Old Jan 19, 2011 | 08:00 PM
i dont think there is anything wrong with having the motor in a vehicle, it is a toyota motor and is reliable just not as reliable as others. but if you are going through all the trouble to swap a motor into your 4runner the work and cost of swapping a 3.0 just is nowhere close to being worth it. a 3.4 is much more rewarding and there are plenty of threads and writeups on this website about it
Old Jan 19, 2011 | 08:34 PM
toyota4x4907's Avatar
You're still not answering his question:
No, the 3.0 will not bolt up to the motor mounts. They are at different locations between the two engines.
And yes, why swap to the 3vze? You have a not very common 2nd gen 4runner (4cyl). Why do you want to swap it in the first place? 22re died? Not enough power? What?
Old Jan 19, 2011 | 08:35 PM
yea missing a lot of power
sorry i dont know much about the 3vze so i couldnt answer it i was just trying to give advice in a better engine or just keep his
Old Jan 19, 2011 | 08:45 PM
Instead of thinking of swapping the motor, why not find out what the cause is?
Is the CEL on? Have you checked the codes?
How many miles are on it?
Do you know if the cat. converter has ever been replaced?
Do a tune-up recently? (plugs, wires, cap, rotor, ignition time, etc.)
Has any major work been done recently before you started to lose power?
Are you losing any fluids? Coolant or oil.
Is there any erratic idle or noticeable miss in the engine?
ETC.?!
Old Jan 19, 2011 | 08:46 PM
I didnt loose power i just think the 22re is powerless
Old Jan 19, 2011 | 08:49 PM
Well the 3vze isnt much better Just sayin....
Old Jan 19, 2011 | 08:50 PM
DeathCougar's Avatar
3VZ doesn't have that much more power. Cost to power gain ratio makes it not worth the swap, or the headache. This topic and why this is a bad idea has been covered hundreds of times before.
And no, you cannot simply bolt it in. The motor mounts are in different locations on the frame for 4Cyl and V6 applications.
Old Jan 19, 2011 | 08:58 PM
does the 3vzfe would be a better idea ?
Old Jan 19, 2011 | 08:59 PM
Old Jan 19, 2011 | 09:03 PM
Thats a camry engine....Transverse style...
BigBluePile's Avatar
yes...no...wait...what?
