3VZE Swap
Old Jan 19, 2011 | 09:06 PM
Tofer's Avatar
Sponsor
3vze: Power of a 4cyl and the thirst of a V8.....
Old Jan 19, 2011 | 09:11 PM
vital22re's Avatar
totally a bro
red4runner91,
Please stop just posting. Take a moment to search this site and maybe use google and search for toyota swaps. Do some reasearch on the topic so you have a little back ground information on what you are asking. There are other better alternatives to the 3vz. Easier swaps. Take some time to do some research. Otherwise you're just digging a hole for yourself.
Old Jan 19, 2011 | 10:14 PM
olharleyman's Avatar
Just so you can get a good idea my 22re will out pull , out run , out drive and get better m.p.g. then my 3.0 in my 4runners both set up exatcly the same gear and tire wise 5.29's and 35 x12.5 x 15 tires.
3.0 is arond 150-160 hp my 22re is about 140-145hp neither of which is a powerhouse nor a v8 if I was in your position I would 3.4 Toyota or 4.3 chevy it and forget the rest but of the two choices you are looking into the 22re hands down.
My.02
Old Jan 20, 2011 | 05:44 AM
blake.nemitz's Avatar
there has been a 3vzfe swap it has its advantages four valve heads, and a distributor, you do have to use the intake setup off a 3.4. the 3vzfe is basically a 3vz block with 5vz heads. it would be cool but for the money building it a 3rz 4cyl out of a newer taco would bolt right in and have the same power as the 3vze v6
Old Jan 20, 2011 | 09:31 AM
  #25
mmcpeck's Avatar
Yeah was thinking the same thing as blake. I had a Taco with that 2.7 in it and it was a tough engine, felt way better than the 3VZE does in my current '92 pickup. I'd go with that in your 2nd Gen Runner or obviously the 3.4 if you want a V6, but I'd stay away from putting a used 3VZE in it...and that's from someone who actually likes the 3VZE.
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
clok
Aug 1, 2015 09:42 PM
91yotapup
Jul 27, 2015 07:19 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
smiley52
Jul 11, 2015 05:16 AM
