3VZE fuses
Old Jan 18, 2011 | 03:44 PM
mudfish's Avatar
3VZE fuses
after years of flawless jumping of various machinery/vehicles, I did the inevitable and tried to jump my 94 pickup in the dark, in a hurry, like an idiot.
Reversed it. Sparks, cursing, and a molten connection all were the result.
there is NO response, not a light not a buzz, nothing... So I'm hoping/praying it's just a big main fuse, but no idea where to start, and yes I've searched.
Where can I go right away without alotta figuring and searching, I'm trying to get this done ASAP. I'm guessing it's 100a, and if I'm not mistaken from my reading it's bolted in place...
but I've no idea where it is
help?
Old Jan 18, 2011 | 03:56 PM
justin_4runner's Avatar
behind the glove box i believe is the main fuses look there first for a blown one.
Old Jan 18, 2011 | 04:45 PM
MudHippy's Avatar
Yeah, you don't pull it like an ordinary fuse. It's actually 80A, and it's located behind the battery in the fuse box there.
These are in the driver's side kick panel(86-88).
I ain't got no pics for the later years, so here's the FSM.
http://personal.utulsa.edu/~nathan-b.../2powersou.pdf
Old Jan 18, 2011 | 09:04 PM
bugs1961's Avatar
The 80amp fuse is bolted in and can't be pulled out easily. Remove the fuse box and take the bottom part off. You can see the bolts from the bottom and you can remove them from the bottom. 8mm wrench as i remember from the last time I blew that fuse.
Old Nov 23, 2018 | 07:00 AM
gilesitis's Avatar
What’s the 80a for?
Do you know what the 80a fuse is for?
Old Nov 23, 2018 | 08:51 AM
millball's Avatar
Says right on that image that it is the main charging circuit fuse between the alternator and the battery.
Old Nov 23, 2018 | 09:25 AM
scope103's Avatar
Heater, taillights, radio, gauges, ... And the generator. Here's the diagram: http://web.archive.org/web/201204170.../2powersou.pdf
Both starter and EFI are downstream of that circuit, so you're not going anywhere when that fuse opens.
RyanJ989
11
Apr 7, 2021 09:41 AM
MadMax48
Mar 3, 2020 10:33 AM
Gone Fission
Sep 4, 2015 12:18 PM
