Oil in breather tube (3VZE)
Old Jan 17, 2011 | 12:18 PM
coopster's Avatar
From: exo-reality -wave if you see me; Front Range, CO
Hey. I have a (94) 3vze that I purchased, it does run.
I did a comp.test - all 6 about 155-170 psi. In the process of pulling intake air tube off throttle body, found quite a bit of oil in there. And in tube back towards air filter. Looks like theres oil beyond the throttle plate as well.
Anyone have a clue as to why that might be getting oil, or from where? TIA
(Sorry if this is also asked/answered elsewhere, but I can't find it using search.)
Old Jan 17, 2011 | 03:52 PM
MudHippy's Avatar
I know precisely why. You have a malfunctioning PCV valve, either that or the hose from it to the plenum chamber is clogged/cracked/leaking. Have you found these things yet? Here's a clue, on top of the passenger's side valve cover. Here's another, if you'd like those compression #s to stay that way and not get any worse, fix it ASAP.
Old Jan 18, 2011 | 07:37 AM
nMe_814's Avatar
i was just going to go test my pcv valve too. and wow , how much more inconvenient could that be.
and just to clarify, i am looking at the right part arent i?
its the only tube that goes into the rear of the passenger side valve cover?
dumpster84
Apr 30, 2016 06:03 AM
adammtb
Jul 27, 2015 11:57 AM
colasurdo
Jul 18, 2015 07:06 AM
colasurdo
Jul 17, 2015 08:28 AM
88yodabasket
Jul 13, 2015 01:32 PM
