Upside down headgasket symptoms?
Old Jan 17, 2011 | 04:55 PM
boosted_dsm's Avatar
I just put together a motor and had it dawn on me that the headgasket COULD be upside down and now im losing it. debating weather or not to pull the head back off and make sure. will i have oil pressure while cranking if its upside down? how can i tell without putting the engine back together any farther incase she needs to come apart
?/ someone please help
Old Jan 17, 2011 | 04:58 PM
rworegon's Avatar
What motor?
Old Jan 17, 2011 | 05:00 PM
pinoaktwh's Avatar
On a 22re it only seems to go on one way. I don't see how you can put it on upside down,,,not sure about the v6
Old Jan 17, 2011 | 05:06 PM
Sorry guys its a 22re.. can it only go on 1 way?
Old Jan 17, 2011 | 05:07 PM
can the 22re headgasket not be mistakenly flipped? will it not go on? im just have been reading about guys having oiling problems or something and dont wanna have it running to find out thats the problem i have
Old Jan 17, 2011 | 05:10 PM
MudHippy's Avatar
http://personal.utulsa.edu/~nathan-b.../7cylinder.pdf
Maybe you could if you tried, but there'd be a big piece of it sticking out.
BTW, you did this without a book or a manual? How'd you know what the torque specs were?
Old Jan 17, 2011 | 05:13 PM
pinoaktwh's Avatar
the oil drain back is on the rear passenger corner,, look at it and see if there is a loop sticking out of the side on the driver side. If there is nothing sticking out then u must have it on correctly because there is nowhere else for it to be.
Basicly loock at the HG where the head and block meets, it the HG is the same match at the contours of the bolck to head then u have it on correctly,,there should be "NO" HG sticking out from the block. When I say "NO" I mean it should be the same shape.
Make sense?
Old Jan 17, 2011 | 05:18 PM
i used a manual but just am second guessing myself here and want some opinions
ill go check now
Old Jan 17, 2011 | 05:24 PM
just checked and no loop sticking out. i put some oil into the drainback hole and it all drained through. If it was on upside down it wouldnt drain correct? i guess i didnt goof it up phewwwf
Old Jan 17, 2011 | 05:53 PM
If the oil drains back i have no problems correct>?
Old Jan 18, 2011 | 03:26 AM
pinoaktwh's Avatar
I would think u are fine. If u had it on upside down u would, 1. have the loop for the oil drain back stickin out the driver side of the motor. 2. it would probably block the oil drain back totally.
I would think installing the HG incorrectly would involve you not paying any type of attemtion to what you were doin.
You are probably fine. Doube check for the loop onthe driver side make sure there is not one there. If it is not, you are good to go.
Try not to over think it.
Larry
TheBFA
Feb 15, 2020 06:55 AM
Longbed 90
Mar 11, 2019 12:38 PM
alimant100
Jan 20, 2016 05:58 PM
beltcutter
Sep 30, 2015 06:14 AM
_Nicco_
Sep 21, 2015 03:06 PM
