PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 [109] 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 3.0 coolant hose against firewall
  2. ECM questions
  3. engine fuse box decal
  4. What could be leaking oil from the top passenger side of my motor?
  5. Speedometer cable
  6. A/C belt tension '86 pickup
  7. 88 3.0 start then die!!! help!!!!!
  8. 93 Runner Dies with right signal light?????
  9. ENGNBLDR cam or lce
  10. 1994 22re 4cyl No Fire!?
  11. stock Ubolt size please
  12. IS oil expander ring SPRING necessary?
  13. 22re camshaft
  14. 90-95 4 runner vs. Xtra cab frame differences
  15. headlight covers for 84-89 style grille
  16. Steering box swap
  17. 1994 mt ecu
  18. Broken water pump & shaft 87 22re
  19. 22r turbo?
  20. 4Runner rear spring bump-stop
  21. Electrical Connection off rear of 5spd Trans
  22. I need a football field to get my truck to stop!!
  23. 86 22r Won't idle - List of things to check
  24. ANOTHER code 71 question
  25. webber carb?
  26. Fuel Injector Timing
  27. Fuel gauge
  28. howling and vibrating with high RPM's
  29. SR5 cluster conversion
  30. windshield trouble
  31. vapor lock 3vze? desperate!!!!!
  32. 22RE horrible gas mileage
  33. 87-89 pickups
  34. New tires 89 4runner coopers new AT3 all terrain offroad tire (pics
  35. White smoke, weird smell when i turn off car
  36. Bed side/Quarter panel
  37. Diff oil color question.
  38. Pinion Flange nut came loose- possible damage extent.
  39. isr mod
  40. Somewhat newb question regarding new truck
  41. 22re Engines
  42. New mod shopping spree!!
  43. O.b.a. question
  44. Shes Alive
  45. squeaky rearend/undercarridge noise
  46. Just fired it up
  47. Benefits of Exhaust Header??
  48. Ignition switches on different years interchangeable???
  49. 88-89 3VZE ECT Pinout
  50. exhaust sounds
  51. Post-accident restoration questions
  52. Swapping parts from 2nd gen to 3rd
  53. nooob here with a bit of a wiring question!!
  54. Shorting Fuses and wiring help.
  55. What radiator to buy for 88 P/U 4x4 MT?
  56. reasons for bad idle/miss
  57. Where is the voltage regulator on an 86 22R?
  58. '95 3vze way tight valve lash - huh?
  59. early 22r head
  60. help with headlight high beam problem
  61. 31's are rubbing
  62. supra AFM clarification
  63. 22re idle is 'sometimes' fast when hot (1990 4x4)
  64. 1991 Toyota Pickup Clutch Pedal Help
  65. Locking nut on AC dummie pully??
  66. Roof Rack Rails mounted on a 4runner topper
  67. Tranny and Transfer Case levers hitting
  68. Rear Driveshaft compatibility
  69. Toyota Pickup Fuel Tank
  70. Auxiliary fuel tank for 1st Gen 4runner
  71. 22r radiator building boost
  72. Photo help needed
  73. o2 sensor male plug
  74. Clutch....
  75. Heater Control Issues
  76. AC expansion valve adapter issues
  77. Price of Toyota Red coolant
  78. 22r Timing chain replacement
  79. Rear leaf spring greasable bolt size
  80. Starter issues
  81. Stalling an automatic 22RE
  82. Need Help Passing DEQ
  83. 3VZE rough idle
  84. TPS issue..
  85. power steering line
  86. V6 Upgrades/Interchanges from 22RE
  87. Oil pressure vs. Oil viscosity Question?
  88. Wiring help needed for O2 sensor
  89. 94 P/U 22re stumbling accel, poor fuel mileage
  90. Charred fuel pump plug!!!??
  91. 1988 22R-E Help. Ran great up till now. Lacks low end torque/ rough idle.
  92. 4.10 Gears & 35x.12.5?
  93. Leaking Rear Differential (with picture)
  94. Maglite Holder Pic
  95. 3.0L 3VZE head rebuild advice
  96. 88 Pickup Rear Driveshaft
  97. Water Leak in '94 4Runner
  98. 89 4runner for my first vehicle
  99. Bad vibration from rear
  100. 20r exhaust manifold
  101. Quick 4runner tailgate question
  102. 1986 single cab transplanted on a 1985 4runner frame?
  103. 22RE has several issues....any suggestions?
  104. 86 22R Newly Rebuilt Engine, Low Idle/Stall First start up
  105. Axle change a breeze & other myths & legends
  106. safari snorkel ?
  107. Can Coolant go bad in storage?
  108. ? Adjustment screw on efi
  109. 33's with stock suspension.
  110. Faulty chain tensioner?
  111. 1987 4runner idle problems
  112. 1988 22re spark plug / oil help
  113. Head gasket, cracked block, or other?!?!
  114. engine overheating
  115. Sunroof on 1986 extra cab
  116. Starter not engaging?
  117. Rear crank bearing cap
  118. 2 piece to 1 driveline swap advise please.
  119. 87 4runner ac ?
  120. overheating when using heater only?
  121. one piece stock front bumper
  122. Alternator wiring problems
  123. waterpump, fan clutch, thermostat, radiator
  124. Question About torsion Bars
  125. Performance issues - related to timing?
  126. Air Ducts
  127. 1990 22re running issues
  128. Roof racks make a difference in MPG!
  129. Obsolete Seal retainer gasket?
  130. Rotor removal
  131. LC Coil/BJ Spacer Lift Finally On!
  132. 1988 Toyota 4Runner Starter Issue
  133. A340 going crazy
  134. Transmission trouble.
  135. Need Help Installing New 3vze
  136. Clunking, knocking somewhere back there
  137. 22r auto - low idle when in gear
  138. 94 Pickup Knock Sensor Pigtail Ground
  139. Duracool, anyone make the switch?
  140. Do OEM Toyota timing components have any branding on them?
  141. Replacement 2nd Gen 4runner quarters
  142. Remove 22RE Head With Manifolds Attached?
  143. smittybilt rear on a 2nd gen 4runner
  144. Failed smog, crummy performance
  145. Coolant in my oil
  146. '86 22R Auto - Rough and late shifting
  147. Rear bumper that works with body lift
  148. Mysterious Current Draw
  149. My Wonderfull '86 4Runner!!!
  150. 93' sr5 4x4 axle seal keeps leaking
  151. Looking for 22re info for a build.
  152. Rear wheel bearing play cause of vibration? (video)
  153. Got a new 4runner!! lots of pics
  154. Cannot remove 3rd member (spot welded?)
  155. Quickie Head Gasket Job Tips?
  156. Metallic rattle
  157. tranny install problem! Need lots of help!
  158. Coolant Leak Metal Pipe
  159. EGR totally dead?
  160. 87 4runner build FINALLY STARTING
  161. Does this timing cover look wrecked to you? [Pics]
  162. truck is sluggish and sometimes stutters at lower rpms
  163. W-56 perfect rebuild pics
  164. Slow to start
  165. 22r engine rebuild question
  166. 87 4runner 22re running rich
  167. Quick question on these exhaust bolts....
  168. Injector wiring on 22RE
  169. 88 4runner Rear Heater Help
  170. AC evaporator connection problem
  171. Slurping noise? Video inside!
  172. massive oil leak front of head
  173. Strange power drain problems.
  174. Fuel Circuit opening relay location?
  175. '90 4runner running issues
  176. 88 3.0 auto CLUNKING noise
  177. '88 4runner factory hitch install help
  178. 1st Gen 4Runner Top Storage - Will this hurt my topper?
  179. transfercase bolt torque
  180. What is this air intake hose?
  181. Top radiator hose housing
  182. weird brake issue
  183. 92 toyota maf problem
  184. Who Sells New Throttle Cables?
  185. Heater/Fan issues.
  186. AC button lights up, compressor intermittently works - bad connection expected
  187. Help don't know why my suspension is horrible?
  188. Brass door hinge bushings?
  189. Need help disabling specific fuel injectors...
  190. 22re Smoking in my 89 4runner
  191. Truck Just Started Missing
  192. fender flares
  193. 22ret - which vacuum lines can I get rid of?
  194. Transmission problems
  195. Crazy ideas about pickup vs 4runner suspensions
  196. Window is Wack! any pointers..?
  197. Mystery Leak 3VZE Questions
  198. hesitation during acceleration
  199. Getting more horsepower?
  200. 3L V6 Starter Solenoid Repair
  201. replacing carpet with anti-fatigue mat
  202. Local Toyota dealership offers remanufactured clutch and pressure plate only?
  203. Swaybar delete = lean?
  204. A little Help Here Leaking Coolant
  205. Clocked T-Case Adapter now stuck in 2H
  206. 2nd gen 4cyl 4runner
  207. Rear spring pad placement???
  208. 22re wiring + cranking problems
  209. '88 floor pan questions
  210. factory diff and ifs with 4.88 fit pickup?
  211. Backing Plate Eliminators...pros and cons????
  212. No start after mudding
  213. Tach for 88 and 94 PU?
  214. truck sounds like a mini deisel!
  215. non cali 22re into cali truck
  216. Should i do a new engine, re-gear, or let the old Yota go...
  217. A/C and starting issues
  218. Problems starting after engine swap
  219. 1986 toyota turbo efi
  220. 95 4Runner - cut out on I-state, now won't crank
  221. 1st Gen Runner E Locker questions
  222. Using duck tape and bailing wire to fix a fuel pump
  223. 93 pickup 3.0 timing
  224. Smog issue
  225. Fluctuating oil psi
  226. U Joint size 95 PU 4x4?
  227. i need some help figuring out if this is really a spun rod bearing
  228. opinions on lift kit (brand, ride, etc..)
  229. Intermittent start problem
  230. 22re motor
  231. Knock sensor removal procedure?
  232. Replace rear coils or put in "air bags"
  233. Yet another Rear window problem... but this one's different! Kinda
  234. installed wrong part no. timing belt (pics)
  235. Blue box?
  236. 90 4runner 22re to 22r: Hesitation/Bogging
  237. Trouble shifting while wheeling
  238. 94 pickup 22re knock sensor
  239. Off-Road Lighting Woes - Switch and Fuse Issues
  240. 22RE Engine Dress Up
  241. 1984 Nissan 720 on 1988 4Runner frame. Ever been done before??
  242. About to purchase shocks for my LC/BJ Lift
  243. 3VZE Power at low RPM
  244. 86 Runner rear window won't work anymore.
  245. My first 22RE swap (pics/vid)
  246. My New Gears. Help Me Read Paint? Thanks.
  247. 94 3vze ext cab NO BRAKES
  248. CEL CODE 71 EGR or Modulator?
  249. 85 yota 22re fit in 92 yota 22re????? HELP
  250. Need Help getting lower ball joint back in ASAP!!!
