Swaybar delete = lean?
Old Jun 29, 2011 | 09:07 AM
Boon's Avatar
Ever since removing my rusty, barely there, albeit still working sway bar, my truck has been leaning to the right. What could be causing this?
I know, I know. Better to have just ignored it. I didn't want it breaking somewhere I couldn't just cut it off. And so here we are.
Old Jun 29, 2011 | 09:30 AM
MaK92-4RnR's Avatar
check your leaf springs. maybe a leaf has snapped.
Old Jun 29, 2011 | 09:56 AM
Boon's Avatar
First place I checked. There is no change in the way the truck drives.
I'll say for sure that my leafs are tired, but equally worn.
Old Jun 29, 2011 | 10:00 AM
MaK92-4RnR's Avatar
Alrighty, so are you talking about it leaning when its just sitting? or when you take turns...? the lean is gonna happen because you took the sway bar off... lol
Old Jun 29, 2011 | 10:01 AM
irab88's Avatar
torsion bars, perhaps?
Old Jun 29, 2011 | 04:01 PM
Boon's Avatar
After reading my original post, it seems I could have been more clear. The truck leans while parked, obviously it leans with away from the turn without a sway bar.
Would a problem with tbars cause a lean to one side? Or would it be as simple as cranking one side to level?
Old Jun 29, 2011 | 04:22 PM
MaK92-4RnR's Avatar
if one of your Tbars is relaxed or stiffer than the other, than definitely... it'll cause it to lean. measure from the top of your tire, to the fender on each side. if one is different than the other. then your Tbars need to be adjusted... They're easily adjusted, unless they're rusted out.
Old Jun 29, 2011 | 08:30 PM
irab88's Avatar
i found that lots of pb blaster and a tire-iron works well to adjust them, and tighten to raise, loosen to lower (for both sides)
Old Jun 30, 2011 | 07:54 AM
BMcEL's Avatar
Adjusting one torsion bar to level it side to side may just be covering up a problem. Under no normal circumstances should one torsion bar sag faster than the other, but a previous owner may have adjusted them improperly in the past. It was probably not noticeable before because the sway bar was doing it's job and trying to keep the truck level. Keep in mind that the torsion bars are already under more stress without a sway bar in place and then add more stress to one side by cranking it by itself. If you can afford it I would recommend replacing them, otherwise maybe try relaxing the high side first. You can never be too cautious when working on components as critical as suspension, especially when failure could send your roof on a blind date with terra-firma.
JonG85
Jan 18, 2023 04:31 PM
Ditch Doc
Oct 27, 2015 03:20 PM
A2theK
Oct 14, 2015 07:10 AM
Thamuel_
Domestic Swaps
Oct 3, 2015 11:15 AM
the_supernerd
Oct 1, 2015 09:20 PM
