93 pickup 3.0 timing
Old Jun 27, 2011 | 04:36 PM
sr5yota612's Avatar
a while ago my distributor was pulled out and aout 5 of the teeth were missing off the gear..i put a new one in and cant find the right spot for it to fire..ive brought the engine to top dead center several times and placed the rotor in the cylinder ones position still no luck even adjusting the distributor while cranking over..i just could use any help on how to figure out which cylinder the engine is trying to fire ..thanks
Old Jun 27, 2011 | 07:07 PM
cody o's Avatar
You might have the distributor 180 degrees off. Remember, it turns once for every two turns of the crank shaft. You may have to give the crank shaft another turn, bring it back to TDC, and align the distributor.
I learned this the hard way on my 91 4runner 3vze. I had the distributor 180 degrees off for the above reason. After cranking the engine for about a minute, I needed a new muffler, and a new pair of pants! BOOM!!!!
Old Jun 27, 2011 | 08:10 PM
toyotacharles's Avatar
i agree with 180 off on dist, also double check the inside of cap to make sure you are lining it up as the cap does divert through several chanels crossing over. Have you checked the cam to see if the damage done to dist damaged the gear protion of cam. a quick way to check would be to removed dist cap and crank engine and see the rotor turns smoothly or at all. had a bearing on dist sieze and shoved gear down shaft to where it is not contacting the cam gear
Old Jun 27, 2011 | 09:21 PM
73pinto's Avatar
3rd on the 180 also make sure u put the dissy a tooth back so when you install it it lines right up
Old Jun 28, 2011 | 02:35 PM
sr5yota612's Avatar
yea i ve been puttin the gear a tooth back to align it correctly ill have to give the 180 flip a try and i checked the cam gear when my distributor was out it feels fine, and from what i could see looks okay..my old distributor on the other hand the gear was as sharp as a razor blade it was pretty beat lol
Old Jul 3, 2011 | 10:47 AM
sr5yota612's Avatar
well none of the above did anything, ive repeated the process a number of times and its really getting to me any other help..or should i just take it to a shop?
Old Jul 3, 2011 | 11:11 AM
wd21_sr5's Avatar
stupid question but I fell victim to it myself out of sheer not paying attention... You DID plug the dizzy back in after dropping it in?
Old Jul 3, 2011 | 09:51 PM
BC-Luc's Avatar
helps to find tdc. take out the #1 spak plug and turn the engine over using a rachet, 19 mm socket i think. The compression stroke will push more air out. I used the air line from a compression gauge, use you thumb and cap the air line.
From there fine tune by lining up the timing mark to zero degrees. Then insert the distibutor while lining up the marks on the distributor and the gear with the mark on the engine.
If the engine doesn't run, your out 180 degrees, turn the engine till the timing mark comes back around to 0 degrees.
Good luck, Luc
Old Jul 5, 2011 | 09:19 AM
sr5yota612's Avatar
well i puklled my timing cover out and the timing pulleys are off at tdc..whats the best way to pull the belt off and realign the timing
Old Jul 5, 2011 | 09:54 AM
If you belt timing jumped for what ever reason I recommend replacing belt instead of realighnining it. There has to be a resin it skipped. Google a procedure I can't find one at the moment as im on my phone. If you found one before I get off work or someone else posted link before then, otherwise ill find one tonite
Alaskan91
Sep 21, 2015 04:39 AM
Alex Bessinger
Jun 28, 2015 10:05 AM
bprice0077
Jun 25, 2015 07:36 AM
dirtrider0129
10
Jun 24, 2015 12:24 PM
nyk08trx
Jun 18, 2015 09:01 PM
