Locking nut on AC dummie pully??
Old Jul 13, 2011 | 02:05 PM
Scottg97's Avatar
1991 SR5 4x4 xCab 3.0
Is there a "locking nut" on the AC Lower Idler pulley?? Trying to remove AC
belt. Adjusting bolt completely off. Still not moving. Tapped it with a hammer
but it still won't budge. I don't want damage it.
Old Jul 16, 2011 | 03:30 PM
MudHippy's Avatar
I assume you found it.
Old Jul 16, 2011 | 03:35 PM
BigBluePile's Avatar
Nice pic....
Yes. Yes there is. It's the same as the power steering belt idler pulley....it gots a lock nut....
Old Jul 16, 2011 | 03:56 PM
MudHippy's Avatar
Say what now?? There's no PS belt idler pulley on a V6. You loosen the belt tension adjustment bolt on bracket below the pump, then swing the entire assembly up or down until the belt is tight enough before retightening the bolt to 29 ft-lbf. Yes, it's just a bolt/there isn't a lock nut on it either.
Old Jul 16, 2011 | 07:29 PM
Whats a ft-lbf? Couldn't find that in any book
Old Jul 16, 2011 | 08:06 PM
MudHippy's Avatar
Foot-pound (energy)
The foot-pound force, or simply foot-pound (symbol: ft-lbf or ft-lb) is a unit of work or energy in the Engineering and Gravitational Systems in United States customary and Imperial units of measure. It is the energy transferred on applying a force of 1 pound-force (lbf) through a displacement of 1 foot. The corresponding SI unit is the joule.
Usage
The foot-pound is often used to specify the muzzle energy of a bullet in small arms ballistics, particularly in the United States.
"Foot-pound" is sometimes also used as a unit of torque (see Pound-foot (torque)). In the United States this unit is often used to specify, for example, the tightness of a bolt or the output of an engine. Although they are dimensionally equivalent, energy (a scalar), and torque (a vector) are distinct physical quantities. Both energy and torque can be expressed as a product of a force vector with a displacement vector (hence pounds and feet); energy is the dot product of the two, and torque is the cross product.
Conversion to other units
Energy units 1 foot-pound is equivalent to:
1.3558179483314 joules
13,558,179.483314 ergs
0.001285067 British Thermal Units
0.323832 gram calories
0.000323832 kilogram calories or food calories
Power Units
1 watt ≈ 44.25372896 ft-lbf/min
1 horsepower (mechanical) = 33,000 ft-lbf/min = 550 ft-lbf/s
Old Jul 16, 2011 | 08:45 PM
link? You make it overly complicated.
Old Jul 17, 2011 | 08:33 AM
MudHippy's Avatar
That's as simple an explanation as I could find. All you really need to know is:
lb = pound
lbf = pound force
ft = foot
And any combination of those terms means essentially the same thing, foot pound/pound foot(w/ or w/o the term force added). The semantics are irrelevant to most topics of conversation. Meaning:
ft lb = ft-lb = lb ft = lb-ft = ft lbf = ft-lbf = lbf ft = lbf-ft = foot pound(force) = pound(force) foot
Old Jul 17, 2011 | 08:48 AM
What if you don't need feet?
Old Jul 17, 2011 | 02:21 PM
peow130's Avatar
Real men measure in N M
Old Jul 17, 2011 | 07:20 PM
New Mexico?
Old Jul 18, 2011 | 07:57 AM
MudHippy's Avatar
Wink
Ninja Measurement.
N-m specs can be found in the NWM(Ninja Wrench Manual).
Ninjas can do anything more accurately and precisely.
justdifferentials
14
Jun 11, 2017 08:36 PM
mulewright
Sep 28, 2015 10:27 AM
Jason4X4
Sep 17, 2015 08:02 AM
zz_denis
Sep 6, 2015 03:43 PM
Aaron Logan
Sep 3, 2015 08:08 AM
