Slow to start
Old Jul 3, 2011 | 05:00 PM
DavidPayne's Avatar
Slow to start
Hi folks,
I have a 91 4wd truck with the 3.0 3VZ-E engine. Engine is slow to start. When you hit the starter the engines turns over for probably 7-10 seconds before it starts up. After it starts it runs fine. Once you shut off the engine and try to start it right back it starts fine. You can smell gas under the hood but can't see it that it has leaked anywhere. Any ideas on this? Thanks in advance for your help.
Old Jul 4, 2011 | 02:00 PM
the_supernerd's Avatar
If it starts quickly after it is warmed up, then there might be something wrong with the cold start injector or the circuit that controls it. They sometimes start leaking and flood the engine, or if it is not working at all then it would not get enough gas when cold.
Old Jul 4, 2011 | 05:02 PM
sb5walker's Avatar
https://www.yotatech.com/forums/f116...t-3vze-236150/
Old Jul 26, 2011 | 06:00 PM
DavidPayne's Avatar
Fuel now leaking
Hi folks,
I now have fuel leaking on the back side of the engine closest to the firewall. Can't tell where the fuel is coming from exactly. If you follow the fuel line up to the back of the engine it connects to something that I don't know the name of and probably leaking there. Its really hard to see back there without removing the whole air intake. Any help is much appreaciated.
Thanks,
David
Jun 1, 2021 01:51 PM
Colington
Mar 8, 2020 09:51 AM
Doug4320
Mar 24, 2018 10:11 PM
Poncho0206
Jul 10, 2015 06:21 PM
