Photo help needed
Old Jul 13, 2011 | 01:39 AM
BEAHRDOG's Avatar
Exclamation Photo help needed
Hey guys
I've been looking online and can't find a pic that's useful... I need a good picture of a stock 2nd gen V6 air filter box and the hoses that run to it... preferably an auto.
I'm wanting to rip out the old one and put in something better, but my truck is from japan and I'm fining more and more things that are just a little different from the 4Runners, and I'm thinking this is one of them.
Old Jul 13, 2011 | 04:26 AM
BEAHRDOG's Avatar
okay.. found a few useful pics in an ISR mod page... so far, mine's looking fairly different... It's got tubes running everywhere... I'll try to post a pic of mine later... maybe someone can tell me what they're all for...
... maybe I should've put this in the newbie section.. *shame*
Old Jul 13, 2011 | 04:30 AM
dropzone's Avatar
Fossilized
Somebody must have moved it because this isn't in newb tech....
Old Jul 13, 2011 | 04:46 AM
waskillywabbit's Avatar
Most folks are asleep at 4am and you won't get a response in 3 hours
:wabbit2:
Old Jul 13, 2011 | 05:13 AM
BEAHRDOG's Avatar
LOL... I didn't expect one, Wabbit.. just figured I'd show I was making the effort to figure things out for myself... lol
Old Jul 13, 2011 | 05:32 AM
You mean you don't want to be spoon fed?
Probably gonna have a hard time finding pics of that stuff except maybe on overseas forum.
:wabbit2:
Old Jul 13, 2011 | 02:18 PM
BEAHRDOG's Avatar
no no... I want to see the 4Runner intake... I want to do an ISR mod on mine, but I'm trying to figure out how...
check out the pics of what I've got... maybe you can help me identify things..
https://www.yotatech.com/members/bea...ms-intake.html
Old Jul 13, 2011 | 03:05 PM
MudHippy's Avatar
For the ISR mod, just deal with everything that connects behind the AFM. The PCV breather and the "intake silencer" are the only lines you need to concern yourself with. If you aren't going to remove the resonator on the air filter box, and/or the entire air filter box too that is.
I've never seen an air filter box with the resonator on the bottom/side, and with a VSV bolted in it's place on top like that. That is a bit strange. I can tell what it is though. It's the VSV for the part with the screw looking piece next to it, the A/C IACV.
That's the input/ouput lines that run into/out of the PS IACV. Also, very strange placement of it. Never seen one of those setup like that either.
My question is:
How does that resonator on the side of the air filter box, normally positioned where the VSV is above it, connect to the air filter box so it can recieve filtered air? Is it connected to the other resonator/"silencer"? Or are they just one piece instead of two seperate pieces, like the ones we have are???
Old Jul 13, 2011 | 11:22 PM
BEAHRDOG's Avatar
It's right hand drive...everything is in some place weird.. including the driver..
Just want to be clear, what's VSV? "IACV" = Idle Air Control Valve? (I'm horrible with abbreviations)
looking at it all now, I think I've got it figured out...
Rip out the silencer (blue) and run a new line from circled bit to the new intake pipe.. that and the PCV line and I should be good, right?
Old Jul 14, 2011 | 10:22 AM
MudHippy's Avatar
Yes, that should do it then.
VSV = Vacuum Switching Valve.
It's an electronic valve that, when signalled by the ECU to open, allows vacuum pressure transmission through it. In this case the vacuum pressure, or lack of it, controls the actuation of the A/C Idle Air Control Valve. Which when opened allows a measured amount of air flow to be redirected to the intake plenum chamber raising the idle speed by a set number of rpm. Which is why an IACV is also sometimes refered to as an "idle up valve".
bigjstang
Jun 2, 2025 03:56 PM
icentropy
Sep 16, 2020 02:47 PM
Road Bull
Oct 10, 2015 04:55 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
mickyd9990
Jul 6, 2015 09:01 AM
