Who Sells New Throttle Cables?
Old Jul 1, 2011 | 08:48 PM
xalier's Avatar
My throttle is sticking so I wanted to get a New cable and I have searched all over the place and also the local parts stores. I usually leave the dealership to my last choice except certain things you know. I figured some of you guys have experience this before so I was curious where you got yours... any info is greatly appreciated.
1990 P/U 4WD 22re
Last edited by waskillywabbit; Jul 2, 2011 at 05:01 AM. Reason: Thread history shows you've had ONE thread deleted as it should have been
Old Jul 2, 2011 | 05:02 AM
waskillywabbit's Avatar
Dealership or online Toyota parts house (dealership)
:wabbit2:
Old Jul 2, 2011 | 07:52 AM
HawkStrong16's Avatar
You can try your local junk yard as well. You might be able to find a good one. Or take yours off and try jamming some WD-40 down the cable to try lubing it up. I've had a little success with that on my GMC. If its not sticking bad you should be alright. Mine was sticking horribly. It still sticks but its alot better
Old Jul 2, 2011 | 09:12 AM
scope103's Avatar
It's about $70 at http://www.toyotapartszone.com/oem/t...180-35060.html [this one is not the right part for your rig; it's much easier to use their site, and the dealership for that matter, if you supply the VIN).
Note that it depends on whether you have cruise control. Also, remember that you have several cables connecting to the throttle plate (mine has one for throttle pedal, ATM, and cruise). You might want to pull out the suspect cable first to see if that really is the one that is sticking.
Old Jul 2, 2011 | 10:13 AM
xalier's Avatar
i hear ya.. well it rarely does it but when it does it will rev wot and ill have to cut the key switch off before it hits the rev limiter till it frees up. no more than a 2-3 seconds. it doesn't have cruise and its a 5 speed, so theres only one cable on mine.. I have taken it off and messed with it and it all felt good never stuck but it dont do it all the time. I have cleaned the TB and blade good and dont suspect it being the problem. It did it last nite leaving work and gas pedel got hard and i had to stomp it to get it back up. so its dealer ship or toyotapartszone?
Old Jul 4, 2011 | 10:09 AM
xalier's Avatar
are they any more toyota parts sites that you guys use or is toyotapartszone it?
Old Jul 4, 2011 | 01:47 PM
fdp101452's Avatar
Ive used Toyotapartscenter.net several times and always had good luck. Talk to Jim, he knows his stuff....
Old Jul 4, 2011 | 03:22 PM
TNRabbit's Avatar
Get a grease gun needle & try pumping it full of grease first~
kazuya2416
Apr 5, 2024 02:17 AM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
rbh261
Jul 13, 2015 12:04 PM
shar
Jul 9, 2015 12:38 PM
