31's are rubbing
Old Jul 14, 2011 | 06:01 AM
94lux's Avatar
31's are rubbing
I bought a 1994 toyota pick up v6 4x4 extended cab this winter and plan on using it as a hunting truck. no intentions to lift it just a nice truck to get down some logging roads. i put 15x8 cragars with 4 inch back spacing on the truck with 31x10.5 general at2 to lift it a little and give it a better look. now the problem is the driver side rubs when i turn left. the passenger side clears by a lot when turned to the right. i dont get it..what could be causing this? didnt the sr5 come with 31x10.5 stock from the factory? Also when i fully turn to lock i get this metal on metal sound grind pop sound going in either direction. and i replaced all the tie rods ball joints and shocks in the front and it is aligned.
Old Jul 14, 2011 | 06:08 AM
flashkl's Avatar
its the high backspacing wheels. When you turn hard they swing in a wider arc than they would if you had em mounted on stock rims hence the rub.
Old Jul 14, 2011 | 06:10 AM
flashkl's Avatar
you can adjust your DS steering stops to stop the rub
Old Jul 14, 2011 | 06:21 AM
Yotard's Avatar
I don't know why either, but I also only rub on the DS.
Old Jul 14, 2011 | 07:52 AM
highonpottery's Avatar
WHERE does it rub?
Old Jul 14, 2011 | 10:18 AM
94lux's Avatar
it rubs way before the pinch weld on the bottom of the fender...i know its not back spacing a buddy has the same set up just a 93 and he doesnt rub at all not even full turn on the trails
Old Jul 15, 2011 | 06:58 PM
blue_CA_yota's Avatar
This is your steering stops.. originally there were plastic caps over a bolt which contacts the lower control arm on the front side. If your truck is like mine, these plastic caps are worn through, broken, and useless.. I get the same noise, on full lock, when the suspension cycles (even slightly)..
My runner makes so many noises, the steering stops barely phase me.. if it bothers you, you can replace the steering stops (I'm sure they're cheap from the dealer), or just don't turn to full lock..
Old Jul 17, 2011 | 01:08 PM
94lux's Avatar
thanks blue CA yota. i put my truck on a lift today and found out my torsion bar is badly bent and thats why my tires rub. any one know who makes a good torsion bar and where i can get them?
Old Jul 17, 2011 | 03:45 PM
flashkl's Avatar
why would a bent t-bar cause rubbing?
is it just sitting lower on that one side??
myotherrideisayoshi
Sep 29, 2015 05:41 AM
Kylenicoll33
Sep 17, 2015 08:40 AM
matt1833
Sep 16, 2015 07:11 AM
langry345
Sep 14, 2015 03:36 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
