Tranny and Transfer Case levers hitting
Old Jul 13, 2011 | 11:31 AM
BlindfoldMemphis's Avatar
Hey guys so I am new here and new to Toyotas and 4x4s. I just bought a 88 4runner 3.0 and the the stick shift in second gear hits the transfer case lever in 2Hi . Now I don't think thats supposed to happen, the PO said that they had a new clutch installed at a garage about 500 miles ago, and they stole his front drive shaft, so i am wondering if they did that because they couldn't get it to fit because they put the tcase back on wrong? Also am I supposed to be able to see the ringgear and flywheel from the the bottom?
Thanks a lot. Any help is appreciated.
Old Jul 13, 2011 | 11:49 AM
waskillywabbit's Avatar
Shifter in backwards.
No. You shouldn't be able to see it.
:wabbit2:
Old Jul 13, 2011 | 12:11 PM
vital22re's Avatar
totally a bro
sounds like a backwards shifter and they left the access plate off the bottom. I would not be supprised if they did not install the top bellhousing bolts on the transmission.
Old Jul 13, 2011 | 01:13 PM
Terrys87's Avatar
Went through that last week. When I was in Reverse an Tcase in 2 Hi, they would hit. The hardest part can be getting the C-clip back on that holds the round cover on.
Old Jul 13, 2011 | 01:36 PM
MudHippy's Avatar
It's called a stiffener plate.
Old Jul 13, 2011 | 02:00 PM
vital22re's Avatar
totally a bro
yes, that plate. You'd be suprised how many of those get "lost" when some shops do clutch jobs. Or they on the 3.0 they leave the upper most bolt off.
Thanks for the clarification Mud.
Old Jul 13, 2011 | 02:04 PM
Thanks guys, I'll get that plate soon. Do you guys have a link to a good shifter reversal? I can't seem to find one and have no idea on how to even start to fix it.
Old Jul 13, 2011 | 02:23 PM
Yeah. thanks again, I figured out the shifter, and the C clip was a pita to get back on.
Old Jul 13, 2011 | 02:42 PM
MudHippy's Avatar
Glad to hear it.
Yeah, I've forgotten to put it back on myself. Until I got down to those bolts at the bottom and realized...umm, something doesn't look right here. Dammit! Now I've gotta back those PITA bolts at the top off so I can push it back far enough to slide it in! And then do it all over again!
What I can't figure out at present is the part number for that little bugger. Why am I not able to find that thing listed where it should be? Well, there's the bell...round 2! Wish me luck!
Old Jul 15, 2011 | 01:01 PM
MudHippy's Avatar
Found it! No wonder I had such a hard time, it's not actually called a stiffener plate.
11361 COVER, FLYWHEEL HOUSING UNDER 11361-65011
4x4-runner
Apr 18, 2017 09:08 PM
4x4-runner
Dec 27, 2016 01:58 PM
Chumlee780
Nov 13, 2015 03:18 PM
yourrealdad
Jul 29, 2015 11:08 AM
crashburnoveride
Jul 10, 2015 06:39 AM
