AC expansion valve adapter issues
Old Jul 12, 2011 | 09:23 AM
Luther Grimace's Avatar
Hey Guys,
So I just got done retrofitting A/C into my 87 4runner from parts off of an 88 4runner. After installing all the parts, it held a vacuum and was filled with R-12. The air just was not getting cold enough. The coldest it got was around 53 degrees.
So I drove it to work that day and running the ac but it just wasn't getting cold enough. I suspected the expansion valve was stuck closed. On my way home, my high pressure line out of the compressor busted. So I replaced hose and the expansion valve.
Here is my issue. The TXV that I bought had an adapter to make it fit because the fittings are larger on the new TXV. I replaced the O rings where I saw they went but in the adapter there was a bevelled nozzel piece that seated into the adapter. I saw no place for the O ring to go. After putting it all back together, now it won't hold a vacuum.
Has anyone had any problems with the replacement TXV adapter? I may be overlooking where to place the O ring.
The new TXV part number is Factory Air 38616
The Factory TXV part number is a Denso 047500-0640
Thanks for the help guys
Old Jul 13, 2011 | 04:25 AM
cody o's Avatar
Sounds like it may have been over-charged. That would explain both the high low-side temperature, and the busted hose.
Old Jul 13, 2011 | 11:58 AM
The MAN's Avatar
there should always be an o'ring... if you can't put one in, then there's your problem
get rid of that aftermarket junk and get the denso part
Old Jul 13, 2011 | 01:11 PM
I contacted a local ac shop about the flare type adapter fitting and they said as long as they are good and tight they work fine. I am going to replace the o rings at the firewall connections and on the hose I replaced for good measure and see if that fixes it. If not I will be hunting down a Denso TXV
bigjstang
Jun 2, 2025 03:56 PM
montanatruck
Feb 26, 2017 07:07 AM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
crashburnoveride
Jul 10, 2015 06:39 AM
