'88 4runner factory hitch install help
Old Jul 2, 2011 | 02:21 PM
JAvendan's Avatar
hello and happy 4th everyone!
i bought a factory hitch for my '88 4runner from a fellow forum member a while ago and have cleaned it up a bit and hit it with some paint.
also got some new hardware/bolts and washers for the install.
i removed the bumper and found where to slide the hitch into the frame rails but it seems like i need another inch or so... meaning it gets wedged between the end of the frame and partly into the rails.
i can't get the thing in there.
anyone have any tricks???
i don't have any pics because i was working on a tight time schedule and had to remove the hitch and replace the bumper before having to leave for the day.
any help/suggestions are greatly appreciated.
joel
Old Jul 3, 2011 | 11:12 PM
Tanker5503's Avatar
if u don't have any BL ur gonna have to remove the tailgate to get it in probably at least i had to. There are only 4 bolts that hold it on. 2 with bolt directly into the hitch and 2 bolts that have nuts i believe all the bolts pass through the frame. it slides and bolts right in if its the right hitch all 4 bolts light up.
Old Aug 11, 2011 | 07:07 AM
JAvendan's Avatar
tanker,
thanks for the info!
i didn't get any notification that you had replied - doh.
thanks again.
joel
Old Aug 11, 2011 | 07:18 AM
xxxtreme22r's Avatar
I don't know which is why I am asking, but does those hitches slide into the frame rails or get bolted to the outside of them? I was under the impression they bolt to the outside of the rails between what would be the bumper and the frame.
Old Aug 11, 2011 | 07:49 AM
waskillywabbit's Avatar
On the outside but two bolts go through frame and into nuts on removable plates that go inside the frame made specifically for the hitch.
:wabbit2:
Old Aug 11, 2011 | 07:54 AM
JAvendan's Avatar
correct!
now, to find the time and git r done
joel
It sounds to me hes trying to slide it on the inside of the frame rails if so that might be his problem.
Old Aug 11, 2011 | 08:16 AM
JAvendan's Avatar
i take tanker's advice and remove the tailgate.
joel
Old Aug 11, 2011 | 08:29 AM
it bolts to the outside of the frame rails for a reason, I would bolt it up the way it was meant to bolt it up. I don't see how a body lift affect anything related to a trailer hitch or the tailgate when the thing is supposed to slide up not forward. But your having a problem putting it on for a reason and that reason is it's not supposed to slide inside the frame rail.
bigjstang
Jun 2, 2025 03:56 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
MMA_Alex
25
Apr 18, 2017 05:07 AM
coryc85
Sep 9, 2015 06:24 AM
