PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 [190] 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. exhaust broke need helpppp
  2. 1993 4runner - Whacky clicking noise
  3. I want a tach and gear indicator light on my dash.
  4. 22RE timing chain Q
  5. 86 4Runner Starting problems. Just clicks
  6. PCV on the 3.0
  7. No Start (no fuel)
  8. Idle bounces....
  9. WTB: Black Steelies
  10. 1 new meat
  11. 3.0 v6 problem for 1st gen 4R?
  12. shovel, flashlight, fire extenguisher, Jack mounts
  13. doing a rebuild have a few questions
  14. questions about these trucks
  15. New CV's shorter than old ones
  16. 1990 4Runner...what's up with the 3.0?
  17. Time to say good bye to my 2nd gen... For Sale, Thanks for GREAT tips and help!
  18. my '88 yota rig
  19. First post - major questions already!
  20. please help..my truck wont start EVERYMORNING
  21. a gallon of gas for 50 cents???? look right here!!
  22. Another Exhaust Question
  23. Rust What ??
  24. front and rear gears question
  25. my truck got busted into..need help with alarm install
  26. mounting a rollbar
  27. Rear Drum Brake Questions?
  28. Help "Loud Ping"
  29. 3 day wheeling trip
  30. factory straight axle and a 22re?
  31. Toyota truck or 4Runner???
  32. 3.0 timing/fuel... HELP
  33. Low speed Vibration
  34. Changing Shifter Seat and Bushing
  35. High pitched noise coming from rear of truck when moving
  36. 22re stiffner bracket ? little help please....
  37. need to change the head
  38. Sorta new paint job
  39. 3.0 Rebuild
  40. ***Timing belt? or Distributor?*** guidance plz!
  41. head gasket 91 4runner
  42. weber 32/36 with no choke??
  43. transfercase question.
  44. Engine mods
  45. New CV's VS Reman'd
  46. 50 state legal sticker for intakes
  47. 4Runner
  48. holy dry T-case Swampman!!!
  49. Radiator problems. Can anyone help?
  50. 93 22re warm start trouble
  51. installed my 2 inch body lift
  52. my door wont open from inside...tricky one
  53. 86 22re ECU wiring does not match pinout.
  54. How do you fool a knock sensor?? Need some electrical help
  55. could I get some help with my alternator problem
  56. On-board Air - Who has it?
  57. timing question.
  58. Buy rolled wreck? Or pass?
  59. Exhaust Setup i have decided on. Any tips or advice?
  60. Head Gasket stuff
  61. lean out on 3vze
  62. LCE 22re complete intake
  63. timing chain "play"?
  64. roof rack???
  65. rear driveshaft yoke Q?
  66. 3.0 Drivers side head?
  67. B antenna mounting help.
  68. Winch Questions?
  69. egr valve no worky?
  70. low, low, LOW power
  71. 91 22 RE missing at idle
  72. radiator drain plug
  73. CMH on 92 4runner
  74. NEED HELP! - Low oil pressure & leaky oil breather
  75. new guy, which lift?
  76. tapping/knocking sound.
  77. 33's on stock height???
  78. 22re turbo idle prob
  79. things to do on a car that has been sitting?
  80. same rattle after rebuild
  81. Park brake wont lock HELP!!!!
  82. How to figure milage with 33's??
  83. 91' 3VZE no crank!!!starter not even clicking
  84. 95 4runner speedo cable... where?
  85. Extending brake lines
  86. lift with stock rims?
  87. Gusseting sliders
  88. ok, this truck is starting to piss me off
  89. need help! 22r not starting
  90. 95 4runner fuel presser damper?????anyone
  91. Speedometer cable and cluster problem
  92. EFI Troubleshooting Question
  93. Broken wire..HELP
  94. Pics of my rig.
  95. 4cyl engine problem
  96. 22RE 5Speed 4x4 Slipping out of Gear???
  97. Final SAS BSin
  98. 3vz-e Swap To 22re!!!!!!
  99. 22-RE Idle pulsing after engine warms up.
  100. Electrical clean up ideas
  101. How to remove plastic license plate frame?
  102. Post your pics: Forced induction only
  103. 2in body lift
  104. Rear spring boost
  105. 2wd gearing
  106. dead truck
  107. Painting????
  108. What brake parts do I need?
  109. brake light disaster
  110. Blown Ecm Fuse
  111. 1st Gen 4Runner Manual Transmission Rebuild
  112. bent frame....wtf!
  113. automatic trans wont go into reverse
  114. 4runners and trucks with 33x12.5 inch tires
  115. mechanical fuel pump
  116. oh golly..another idle problem:)
  117. U Bolt Flip Kits
  118. need help on my 1992 toyota pickup cluster swap
  119. Relocating Transfercase cooler??
  120. What's that part under the bumper called?
  121. Troubleshooting Power Mirror Switch
  122. i could use a little help guys
  123. Here's what I did today...
  124. Another wiper motor gone?
  125. tire and rim question
  126. rear anti lock?
  127. Rusty Fuel Filler?
  128. 3vze Head Gasket Diagnosis (with pic)
  129. Removing U JOINT from Driveshaft HELP
  130. Stock 2nd Gen 4Runner Buildup plan
  131. Dammit Dammit Dammit
  132. Acceleration hesitation / power loss culprits...
  133. LSPV removal?
  134. whats the deal? cheap parts!
  135. Few Q's about my ne beater
  136. 93 pickup Owners manual???
  137. Resale value with a new engine
  138. 94 4runner 2 1/2 inch lift??
  139. wheeling tomorrow, advice?
  140. wrx hood scoop
  141. D&J Rock Products
  142. Whats THE Best way to SPIN DriveShaft to REMOVE flange BOLTS
  143. Help HOW do you plug the Transmission during Drive Shaft Removal
  144. How Could I Make a VIDEO So you GUYS Can best Diagnose My steering LINKAGE
  145. Brakes? WTHeck?
  146. Replaced clutch master and slave still no pedal
  147. Why is my 3VZE idle speed so high?
  148. is a new motor needed
  149. Cluster on 22re with fuel lines and injectors
  150. new injectors=high idel speed, Help!
  151. Grill swap
  152. 86' parts compatible with 88's?
  153. does an 86 22re have a tensioner on the AC?
  154. compatibility issues - 22re to 22re
  155. #3 cyl bad compression 22RE
  156. New TPS reading wrong?
  157. tail light problem
  158. Quick add-a-leaf question
  159. Clutch not popping back to full height.
  160. Debadge '87 4Runner tailgate
  161. 86 4x4 22re AC. Need a tensioner?
  162. 3VZE missing after disconnecting battery!!!
  163. I'm an Idiot.
  164. 83 roll bar on 86 pickup
  165. 3vze coolant distribuiton block.. does anybody have one they want to get rid of
  166. if you gonna replace a u joint should you replace bothof em
  167. ac not working
  168. paint job price????
  169. 94 rear e-lockers
  170. 1990 Pickup CEL 51 After IAT and ECT mod? WONT RUN!
  171. Searching for specific Keyless kit ...
  172. Southern California- need a 22re!!!!!
  173. 95 landscruser leather seats/parts
  174. Removing the steering wheel
  175. engine cut off
  176. Engnbldr motor coming together!
  177. Another A/C Questions
  178. Another YOU TUBE Video HELP me diagnose linkage and wheel bearings
  179. Tube bed/tailgate pics, enjoy.
  180. Another my truck won't start threads
  181. possible clutch issue. Help?
  182. gear drive OR chain drive transfer case?
  183. 1995 4Runner performance Mods?
  184. I need a quarter panel for a 1990 2dr 4runner!!!
  185. ECU Question 22re to 22rt??? (nervousness)
  186. procomp steering stabilizer
  187. Dilemma (not your typical):E-Lock or Detroit?
  188. Pic of 1089s anyone?
  189. Trail-Gear sale? SAS stuff....
  190. unknown part
  191. 7.5" diff install
  192. Another Rear Window Question!!
  193. A/C Swap
  194. compression check with a stuck spark plug?
  195. Throttle position senson necessary?
  196. 2wd steering knuckle arm
  197. Does anybody else hate being under their 4runner on JAck stands
  198. my new daily driver
  199. this PU only has to last another month...
  200. Help me determing if i need new Wheel bearings with You Tube
  201. Help me guess this fluid. I dont think its oil
  202. 1991 pickup 4wd knock sensor wire
  203. Albuquerque wheeling?
  204. What is the best way to tell a bushing is bad
  205. Help! Crossed battery wires and *poof*
  206. Got My Meats On!
  207. Sunroof replacement info? Need directions...
  208. Can I remove Emission stuff?
  209. Circuit Breaker in starting circuit?
  210. Idle problem
  211. flat spots on valve adjuster screws
  212. Transmission upgrade
  213. Power Brake Booster: Upgrade Compatibility?
  214. 90 pickup Dash Light circut
  215. Rock Auto rocks
  216. Hard shifting auto
  217. Az mechanic
  218. Need some wisdom
  219. Weight limit on stock roof rack???
  220. 22RE Mystery engine trouble!!
  221. Gurgling sound when truck starts
  222. dealing with rust inside frame rails
  223. Doing a SAS on my 88 runner.
  224. Signs of a bad knock sensor?
  225. 90 3.slow miss/stumbe/hesitating
  226. Sagging Rear, Endless Problem?
  227. Rear End help...
  228. engine wont rev past 2000rpm?
  229. Trucks starts but won't stay running. 89' 22re
  230. SR5 Cluster
  231. 4runner 3.0 problems... HELP
  232. Got my rims!
  233. Aussie locker first use and review
  234. Should I do this rebuild?
  235. Help me narrow this problem down QUICK Q
  236. 94 4 Runner Doors And Tailgate Compatibility
  237. Air Box/BATT swap
  238. Brake Question
  239. 3rd swap
  240. 3vze, low on power and crappy mileage
  241. Rusty Bumpers and Wheels
  242. nice 2nd f/s in seattle (pics)
  243. Code 52
  244. tranny problems
  245. Very wierd pulley problem. Please help.
  246. IFS Rattle
  247. 22re mail seal
  248. in need of some Wiring Diagrams...Please
  249. the cost to put an AC unit in a 22re??
  250. Help diagnose my ADD
