Old Feb 9, 2016, 08:43 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications & General Maintenance
Print Wikipost
1995 4Runner performance Mods?
Old Aug 6, 2008 | 02:39 PM
4Runner831's Avatar
Ok right now i got the K&N intake kit i got the Flowmaster super 40 exhaust, and a Jet performance chip(Big Difference) what other bolt ons can i get to help turn my 32 Toyo Mud Terrains.
Old Aug 6, 2008 | 02:41 PM
tc's Avatar
tc
a 3.4 swap
Are you actually claiming that the Jet chip made a big difference, or everything together made a difference?
Old Aug 6, 2008 | 02:42 PM
RobD's Avatar
Take the 3.0 out. Push it over a cliff. That's the fastest that motor will ever go.
Find 3.4 from newer Tacoma/4Runner and drop it in. Spending money on a 3.0 is like polishing a turd.
RobD's Avatar
Originally Posted by tc
a 3.4 swap
Damn, you beat me to it.
Old Aug 6, 2008 | 03:04 PM
abecedarian's Avatar
and other bolt ons... hmm....
... regear?
Old Aug 6, 2008 | 04:30 PM
Matt16's Avatar
Regear. It makes a tonne of difference even going from 4.10 to 4.56. Second (off road performance) buy a locker- I'd hate it if I'd invested in MTs and some truck with ATs was able to go farther.
Old Aug 6, 2008 | 04:42 PM
>snip<
... the Jet chip made a big difference...
>snip<
the only thing the jet chip does is alter the coolant temp sensor signal to cause a slightly richer fuel mixture. it doesn't affect timing, or anything else for that matter. and it doesn't even do it intelligently. it's just a resistor biasing the coolant sensor towards colder engine temps.
Old Aug 6, 2008 | 06:50 PM
Jay351's Avatar
Yep, those chips are junk. Im sure you're getting less then average fuel mileage now.
As for mods:
Intake (you seem to have it covered with the overrated K&N fipk)
Cams (expensive, hard to install, worth the gains if you can)
Headers (again expensive, hard to install but they are worth a few hp)
Other then that, you need to get into oversized valves and so forth, it gets pricey quick.
I wouldnt bother doing anything that expensive unless you are rebuilding the engine and want to get it running better.
Save for a 5vfze or even the 1uz swap. Much more power available from those engines.
Re-gear your differentials to 4.88 if you have a 5sp or 5.71 if you have an auto. This will help low end power
Old Aug 6, 2008 | 07:38 PM
tc's Avatar
tc
That was kinda my point ... with as locked down as ALL Toyota ECU's are, chips can't make much of a difference.
Old Aug 8, 2008 | 09:39 PM
4Runner831's Avatar
ok so the k&n kit i vey overrated and too expensive but ca is bitch bout smog. and the jet chip helped my acc. dramatically.
Old Aug 8, 2008 | 11:09 PM
Matt16's Avatar
Buy a Supra?
Old Aug 9, 2008 | 04:06 AM
STEVE_R's Avatar
mmmm, i say sell the aftermarket crap you have on there now to some other sucker, part out rest of motor on e-bay, and drop in a 3.4. i'm just waiting for the day my motor goes bye-bye! ok, so i help it along at times! checkout asap motors, the 3.4 is actually $200 cheaper than the 3.o (3.4-$1500 3.0-$1700).
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
icentropy
Jul 11, 2015 07:21 AM
Nickdigg
Jul 7, 2015 06:04 AM
