Help?! My truck has demons!
Old Aug 3, 2008 | 10:41 AM
sts2usnss's Avatar
It all started a week or so ago with the smell of gas coming from the right side of my engine bay. I am assuming this is either from the fuel pulsation dampener or from a leaky o-ring on one of my fuel injectors. I am still working on trying to figure that part out.
Now here is where it gets interesting...
About 20 minutes ago I went outside to smoke and was standing about 10 feet from the front of my truck when all of a sudden it started leaking antifreeze. The truck hasn't been started in two days! I crawled under her to see where it was coming from but all I can see is it is dripping from the bottom of my transmission. Right around the bottom of the bell housing.
Any ideas? (other than time for a swap to the 3.4)
Old Aug 3, 2008 | 10:51 AM
wrnchplr's Avatar
what motor???? the 22re has a water bypass on the back of the head that will leak. the 3.0 has a Distribution block on the intake, it to can leak. as for the fuel smell there could be some things causing that. with the hot days fuel will vaporize causing the oder, on the right side of the engine bay is the charcoal canister. if the filter is bad or a line broke you will also get a smell....
Old Aug 3, 2008 | 11:48 AM
sts2usnss's Avatar
It's the 3.0. and it's not the charcoal canister.
Old Aug 3, 2008 | 12:06 PM
wrnchplr's Avatar
humm good luck with that....
Old Aug 3, 2008 | 12:15 PM
sts2usnss's Avatar
Yeah, if it were happening to someone else those would be my exact words also...
Old Aug 3, 2008 | 12:52 PM
aviator's Avatar
I had that two years ago and it was actually leaking from the top of the fuel tank. The fuel pump bracket had failed where it was sealed to the top of the tank. Had to get a new bracket from Toyota. price was about $200cdn. installed. also got my fuel sys. modified to use a more easily replaceable GM fuel filter. [my oe filter was worn out and to big and expensive a PITA to replace with stock].
Old Aug 3, 2008 | 01:19 PM
sts2usnss's Avatar
Would there be any hoses that would carry antifreeze running around the back of the engine?
Old Aug 3, 2008 | 03:00 PM
Mr_Martinez1982's Avatar
sho is....
Originally Posted by wrnchplr
...the 3.0 has a Distribution block on the intake....
Old Aug 3, 2008 | 03:01 PM
a bunch of lil hoses+ near exhaust crossover+ time= leaks
duckhead
170
Nov 13, 2017 06:07 AM
MadMax48
Jul 3, 2015 08:26 AM
Crazy_Guy97
12
Jun 24, 2015 04:02 PM
