Low speed Vibration
Old Aug 14, 2008 | 03:06 PM
ttr125mar's Avatar
Low speed Vibration
Im getting a Vibration mostly noticable when decelerating in second gear. Also starting out in second gear. Only when in gear. If vehicle taken out of gear no vibration is present. I just did a frame swap, and have two rear driveshafts both with new u-joints infront of the third. My third did have some play if ratotated left to right but no vertical play. I had three different sets of tires on and didnt make any difference (new tires as well). Any help is
appreciated.
Thanks,
Mario
Old Aug 14, 2008 | 04:03 PM
abecedarian's Avatar
if it only happens in 2nd, then there may be a problem in the transmission.
Old Aug 14, 2008 | 04:51 PM
Camach's Avatar
My truck use to shake when slowing down.. I believe at 20 or 15 mph. I had the tires rotated and realigned, problem went away.
Not sure if that is your same problem but it's worth a try.
Old Aug 14, 2008 | 05:17 PM
Skinsfan6's Avatar
My 4Runner used to shake like that under acceleration or decceleration, mostly at certain rpms. It was a worn out rear end. My ring and pinion had so much slop and wear that they vibrated. There were 361,000 miles on the 4Runner then. I just swapped in a whole rear 86 truck axle with about 150,000 miles on it.
ghostmoney
Jan 28, 2018 11:42 AM
montanatruck
Feb 26, 2017 07:07 AM
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
