Removing U JOINT from Driveshaft HELP
Old Aug 9, 2008 | 09:51 AM
simpsons721's Avatar
Red face Removing U JOINT from Driveshaft HELP
Hey I need desperate Help
I have gotten my driveshaft off my truck
now i cant get the u joint off og the drive shaft i have removed the c washer type rings and
now im trying to push the bearing through by vising a socket to the bearing and pushing it through
do you have any other tips to accomplish this step i dont see any movement starting to happen
and i used pb blast overnight
please help
Old Aug 9, 2008 | 09:56 AM
Team420's Avatar
heat, heat, heat.... if they are original, they are also glued in... heat them up with a propane torch till u see the glue bubble out.
Old Aug 9, 2008 | 10:05 AM
RobD's Avatar
Glue? That's the first time I've ever heard that. My factory shop manual says nothing about glue.
What you've got are caps that are probably rusted in there. I assume you've soaked them down with PB Blaster or something similar.
I had to use a large ballpein (or ballpeen, depending on how you want to spell it) and place the yoke on a 2x4. Using a socket or something else you don't mind sacrificing as a punch, you have to beat the living crap out of the cap by placing the socket on it and trying to pound it out the other side.
Like is shown halfway down on this page: http://www.dodgeram.org/tech/repair/U_joint/repair.htm
Old Aug 9, 2008 | 01:35 PM
Snotrocket's Avatar
Just like RobD said. It can take some hammering to get the little suckers out of there.
When I do it I take it and have somebody press them out though.
Old Aug 9, 2008 | 02:13 PM
RobD's Avatar
Yeah, I had the pound the crap out of the thing to get it to budge. Once it does, it's not too bad.
Old Aug 9, 2008 | 02:43 PM
thook's Avatar
X2...
As well, you may have to pound in one direction, flip the shaft and pound in the other, and back and forth until the caps come loose. My last job was like that. And, I've had others in the past.
There is no glue in the u-joints.
Old Aug 9, 2008 | 07:55 PM
95RunnerSR5's Avatar
mini sledge, torch, and center punch made the job.... well it still wasn't easy
Old Aug 9, 2008 | 08:02 PM
abecedarian's Avatar
... and pound a bit and squirt your blaster, wd, liquid wrench, whatever, and let it soak a few minutes between poundings.
Old Aug 9, 2008 | 08:03 PM
algranger's Avatar
bfh, strong socket, liquid wrench, beer, you should be good to go
Old Aug 9, 2008 | 08:21 PM
YotaJunky's Avatar
cut them out with an grinder and be done with it. You won't be using them again anyway.
Old Aug 9, 2008 | 08:24 PM
would it be too much to ask you to go out to your truck and take pictures and describe exactly how to use a right-angle grinder, or even Dremel, to cut the u-joints out without damaging the drive shaft?
Old Aug 9, 2008 | 11:21 PM
RobD's Avatar
Actually, I had to use my 4 1/2" angle grinder once I got them to move. I could only get one yoke off, so I simply cut through the U-joint between the cap and the main part of the + .
It can be done. Just be careful where your power cord is because you can slice through it very quickly if you're not watching. Don't ask me how I know this.
Old Aug 10, 2008 | 04:14 AM
Lysmachia's Avatar
Worse comes to worse take it to a driveline shop. They are much cheaper than a stealership or even regular shop and they can pop the old out and new one in in no time. We have an awesome one here in Boulder - Boulder Driveline, and he pretty much rules... While your at it (if you go to a ship) have them check your DL balance... It can't hurt!
I usually save my do it yourself ujoint replacements for on the trail repair
Old Aug 10, 2008 | 05:22 AM
Robrt32's Avatar
I don't even attempt to knockem out anymore... I just light up the HOT wrench....
Old Aug 10, 2008 | 06:25 AM
I get what you meant now.
Old Aug 10, 2008 | 06:29 AM
dirtoyboy's Avatar
x2 on the blue tipped wrench!
Old Aug 10, 2008 | 06:51 AM
Team420's Avatar
yeah....my bad.... I was thinking of the u joints i did on a blazer last week... they were glued, just gotta beat the hell out of em. a socket and bfh will be helpful.
Old Aug 10, 2008 | 07:10 AM
frodin1's Avatar
A big vice and an oversized socket works for me.
Sep 4, 2015 09:27 AM
yoder519
Aug 17, 2015 07:12 AM
trailgoat
Aug 13, 2015 05:54 PM
Tonetrk
Aug 6, 2015 10:06 AM
gillesdetrail
Aug 3, 2015 04:43 PM
