factory straight axle and a 22re?
Old Aug 14, 2008 | 07:12 PM
Junkers88's Avatar
Brother in law of a friend showed up with a 1985 SR5 pickup and we were checking it out. He opens the hood and there's a fuel injected motor in there. So this thing (according to him) is all factory with the straight axle and the RE motor.
Rare?
Oh and he's having some real problems passing emissions and is starting to dislike the truck. If he hates it enough I'm going to buy it and transfer all of my goodies to it and have the best of both worlds!!!
Old Aug 14, 2008 | 07:16 PM
Jay351's Avatar
Yep, first year of the fuel injected 22re. Its different then all other years of 22re so its pretty rare. Quite the awsume combo though!
Old Aug 14, 2008 | 07:17 PM
abecedarian's Avatar
sounds pretty stock for an 85. efi started in 84. the options were basically carb'd or efi.
but the efi engine in 85 is different than an 86 efi, as is the efi system itself.
Old Aug 14, 2008 | 08:43 PM
annoyingrob's Avatar
Maybe in trucks, but but the 22R-E was around earlier than that. My 83 Celica was fuel injected. I'm pretty sure the 82 Celicas were too.
Old Aug 14, 2008 | 08:47 PM
scuba's Avatar
dang did anyone else here that crack whip ?!
4Crawler's Avatar
I think the pre-85 (or pre-84 for sure) fuel injected 22Rs were all analog while the '85 and later were electronic. My '85 4Runner came with 22RE from the factory. It is essentially identical to the later 22REs, at least through '87, I have a spare '87 ECU and it works fine in the '85. And I have yet to find anything vastly different between it and that later '80s model engines. Maybe the main difference is the lack of difference between the 22RE and 22REC engines, I have yet to find anything different between the two engine variations in the '85 year, while there are differences in later years.
The 22RE was far more common in the '85 4Runner than in the pickups.
Old Aug 14, 2008 | 08:51 PM
cosmo's Avatar
The first 22R-E came in late 1981, and used an analog EFI system, for total output of 105 hp. The TCCS digital EFI system didn't come until 1984 for trucks/celicas. It resulted in 116 hp and 142 lb-ft. of torque.
EFI was available on all Trucks and 4Runners from 1984 on, although some (most?) '84 4Runners used the 22R.
But yes, the '85 EFI system is unique and different from other years.
What most don't know is that the 22R-TE also came out in 1984. It was not widely advertised, however, until 1986. So if you were in the know, you could perhaps have ordered a factory Truck/4Runner with solid axle and Turbo.
Old Aug 14, 2008 | 08:53 PM
cosmo's Avatar
just remember, the "E" means ELECTRONIC... not mechanical. It was electronic... just started with analog instead of digital. No ECU to speak of in the analog system.
Old Aug 14, 2008 | 08:55 PM
scuba's Avatar
Oh thanks for telling me about this sweet deal...5637 years later !?!
Old Aug 14, 2008 | 08:58 PM
cosmo's Avatar
it's really a shame that the "oh what a feeling" days are over...
they will probably never return.
Old Aug 14, 2008 | 09:02 PM
cosmo's Avatar
I've always wondered why they didn't use an SR5 EFI Turbo for Back To The Future as opposed to just SR5 EFI.
many people do say that the truck was beefed up in order to do the reverse 180, however...
MIGHT it have had a Turbo lurking under that sleek black hood?
we may never know.
Old Aug 14, 2008 | 09:42 PM
scuba's Avatar
so im thinking to myself i was just reading about that truck, then im like, DARN YOU, YOUR STALKING ME!?!
Doc Brown: Well, she's almost finished... four cylinder, twin superturbocharged, with hybrid flux drive... once this baby hits 112 miles per hour, you're gonna see some serious stuff...
Oh we know my friend
Old Aug 14, 2008 | 09:49 PM
Trustyrusty's Avatar
Quite pathetic it had to be souped up to do that, I can do that and I have 33x12.5's and stock gears, then again I could also get 2nd gear scratch when I had my 30" tires too.. My engines fresh though..
we may never know.
Old Aug 14, 2008 | 09:56 PM
eighty5yota's Avatar
i have one! its for sale too!
Old Aug 14, 2008 | 10:05 PM
JamesD's Avatar
What makes the 85 EFI so Unique?
James
Old Aug 14, 2008 | 10:15 PM
89silverpu's Avatar
James
This is a joke right....?
Old Aug 14, 2008 | 10:18 PM
cosmo's Avatar
It was the first year for the "Laser Block" 22R/22R-E. The head was taller and the block shorter. Also the second year for single row timing chains. This is one crucial difference.
As for the EFI itself... well, ask somebody who has one. I think the throttle body was slightly different, as well as the ESA/VAST systems.
Some websites quote 1985 22R-E output as 112 hp instead of the 116 hp advertised by Toyota. I personally always use the 116/142 figures for hp and torque, but some beg to differ.
Old Aug 14, 2008 | 10:34 PM
scuba's Avatar
lol..
Cosmo also forgets (to point out) the fact that 85 was the last year of the Solid front axle.
A highly saught after traight of these trucks..
Old Aug 14, 2008 | 10:36 PM
cosmo's Avatar
what do you mean by "also" forgets? what did I forget first?
Old Aug 14, 2008 | 10:41 PM
scuba's Avatar
That the SFA was exclusive to the 84-85 EFI trucks.
