need help on my 1992 toyota pickup cluster swap
Old 08-10-2008, 01:47 AM
4wheeler808's Avatar
Talking need help on my 1992 toyota pickup cluster swap
aloha!!!!!!!!!
i have one 1992 toyota pick-up with a 5-speed manual trans/22re engine......
i have one sr5 gauge cluster came out from a 1991 toyota pick-up with auto trans/V6 engine..........
just wanna know if the cluster will work on my truck..................what are the steps that i need to do/////or the best thing to do
need all the advice that i can get........
thanks a lot for the help.......................mahalo
4wheeler808 is offline
bump..................
Old 08-10-2008, 06:44 AM
TomThumb's Avatar
Originally Posted by 4wheeler808
aloha!!!!!!!!!
Won't work! 89 to 91 trucks have a cable driven speedo, Toyota switched to digital in 92 then back to cable in 95 again. You will need to have a cluster from the same year and engine size and trans to make sure you don't have any issues. Also make sure you change out the sending unit for the warning light on your truck, to the oil pressure sending unit other wise the oil pressure guage will burn out and it will not work anymore. If you do the dash swap before you you change the oil pressure sending unit, make sure you disconnect the wire for the oil warning light before you hook up the battery or turn the key to be safe.
Here is a link with some info, its for the 2nd gen rigs but a lot of the info will still apply.
http://siestaoff-road.web1000.com/clustertech.html
sorry to break the news, hope this helps
TomThumb is offline
Old 08-10-2008, 10:19 AM
they are both electronic not cable type
Old 08-10-2008, 10:59 AM
toyminator2000's Avatar
You may also have an issue with using the Tachometer. It will need to be re-calibrated for the 4cyl to work properly. It can be done on the tach itself.
toyminator2000 is offline
Old 08-10-2008, 12:52 PM
i think you have to rewire it....cause it came from one automatic
and my truck is 5-speed.......but dont know how
help..................................
Old 08-10-2008, 01:01 PM
JamesD's Avatar
From my knowledge if your truck has manual front hubs it is cable driven, if it has no hubs it is electronic speedometer.
JamesD is offline
Old 08-10-2008, 01:15 PM
89silverpu's Avatar
Not true... I have have a speedo cable in my 89 I just changed it out a couple months ago cause it was squeeking...
89silverpu is offline
Old 08-10-2008, 04:19 PM
i mean the one i have.......
the original cluster on my truck is electronic(4 cyl/5-speed)
and the one im trying to put is electronic too but came out from one V6 with auto trans...........
Old 08-11-2008, 02:48 PM
bump......................
Old 08-11-2008, 05:50 PM
Robert m's Avatar
this might help https://www.yotatech.com/forums/f116...ctures-102656/
Robert m is online now
Old 08-15-2008, 02:14 AM
the cluster i'm trying to put is came out from one V6 with Automatic Trans
my truck is 4 cylinder with 5-speed trans
Old 07-08-2009, 07:54 PM
JBRobins13's Avatar
how do you switch the cluster from 6cyl. to 4cyl. on the tach?
JBRobins13 is offline
Old 12-05-2010, 06:26 PM
firefight's Avatar
If the cluster doesn't work out I would be interested in it let me know... jasondumbolton@yahoo.com thanks
firefight is offline
Old 12-15-2010, 06:02 PM
Jshep92's Avatar
I also have the same issue. my truck is a 92 4x4 4 cylinder. the cluster came from a 94 automatic v6. everything on it works just fine minus the take. I need to figure out how to recalibrate it.
Jshep92 is offline
Old 12-15-2010, 06:49 PM
iamsuperbleeder's Avatar
https://www.yotatech.com/forums/f116...w-pics-179106/
iamsuperbleeder is offline
Weidle
01-21-2019 05:39 AM
Aleeex_u
06-05-2016 06:52 PM
1badyota350
06-28-2015 06:50 AM
Peteyg39@hotmail.com
06-26-2015 08:15 AM
infinityisfive
06-16-2015 06:51 PM
Quick Reply: need help on my 1992 toyota pickup cluster swap
