How to remove plastic license plate frame?
Old Aug 10, 2008 | 06:23 PM
JohnRaven's Avatar
Alright.... How do you remove the 'chrome' plastic frame around license plate???
I've tried, but I don't want to break it!
There's rust behind there and I want to take care of it!
[IMG][/IMG]
Old Aug 10, 2008 | 06:54 PM
abecedarian's Avatar
remove the inside panel from the gate and look.
Old Aug 10, 2008 | 07:17 PM
JohnRaven's Avatar
uhhh, can't... window is in the way lol.
Old Aug 10, 2008 | 07:18 PM
lower the gate and bypass the window motor relay.
or work on it from the inside with the gate closed and window up.
Old Aug 10, 2008 | 07:22 PM
JohnRaven's Avatar
Dang, I was hoping you weren't going to say that!
/will try in the morning
Old Aug 10, 2008 | 07:25 PM
Old Aug 10, 2008 | 08:28 PM
DeathCougar's Avatar
Why are you trying to take that surround off? Its one molded piece, you cannot just remove the chrome. You will be left with several odd shaped holes that will need filled, as well as no way to light the plate OR house the backup lights.
Old Aug 10, 2008 | 08:43 PM
Originally Posted by DeathCougar
...You will be left with several odd shaped holes that will need filled, as well as no way to light the plate OR house the backup lights.
oh, ... I thought we would be able to use your Barbie hair dressing station mirrors and lights...
sorry.
Old Aug 10, 2008 | 08:47 PM
JohnRaven's Avatar
^ lmao
someone forgot to read my first post thoroughly...
I want to take it off so I can deal with the rust BEHIND it!
Old Aug 10, 2008 | 10:45 PM
Indeed, I didn't read the entire post.
You will have to take off the inner panel, as stated.
You can roll the window up and out of the way by clicking the latch in with a screwdriver while the gate is open to trick the system into thinking the gate is shut.
Old Aug 10, 2008 | 11:12 PM
thook's Avatar
Somebody drank lots of beer this weekend......
Not reading the entire post. Shameful for mod upstart.
Old Aug 10, 2008 | 11:16 PM
Too much beer and too much sun. Sides of my head next to the 'hawk got sunburnt, i think i burned off a few brain cells.
Old Aug 10, 2008 | 11:19 PM
thook's Avatar
Ears still ringing, too?
Whattt???!?!?! :d
Old Aug 10, 2008 | 11:27 PM
thook's Avatar
I SAID....ARE YOU'RE EARS STILL RINGING??....RINGING...RINGING...RINGING
Old Aug 11, 2008 | 03:36 AM
and no one is home to answer
Old Aug 11, 2008 | 04:43 AM
pepsibluefloat's Avatar
you can also take off the panel on the back and roll the window up with the gate shut to get to the bolts
Old Aug 11, 2008 | 04:51 AM
dirtoyboy's Avatar
Have you tried burning it off? Thats what I would do....
oh and service manuals usually have some nice suggestions as well
Old Aug 11, 2008 | 05:03 AM
James Dean's Avatar
There are two nuts at the top and 5 plastic squeeze pins that have to be removed. This can be done with the window rolled up if you are nimble. Just had mine off for paint.
1. With the gate down, latch the two side latches to fool the gate that it is closed.
2. Carefully roll the window up most of the way.
3. Use a 10mm with extesion to remove the nuts that are at the top.
4. Then squeezed the 5 pins (2 on each outer end and one at the bottom center).
5. Unplug the two reverse wires and you're done.
Old Aug 11, 2008 | 05:54 PM
JohnRaven's Avatar
Just to prove I actually did it...
Eh, should slow it down for awhile...
Thanks for all the help guys! Sometimes I just can't think on my own
